whyscotty - is there a build log for that system?
Starts off just the Cpu and then I add the 7970's
http://forums.overclockers.co.uk/showthread.php?t=18432216
See diagram and link in post 13
It does. I was also sub'd to your latest...
Thanks
16 x 16 on the Rive is the 1st and 3rd slot(Red)
This was mine running 7970 crossfire b4 I got Titans
IMAGE SNIP
Yes it is![]()
I bought one of these cases recently, with your experience do you think the rads below will fit comfortably
Top - Hardware Labs Black ICE Radiator SR1 360
Bottom - Hardware Labs Black ICE Radiator SR1 240
This looks good too XSPC RX360 120mm Radiator but was concerned it might not fit in the top and clash with the mobo. What rads did you use?
Apologies for the thread hijack![]()
