Temps are fine mate, nothing to worry about. 60 ish. The Twin Frozr III cooler is overkill for a 660 really, but it does keep it nice and cool.Sounds realllllllllly obvious, but what temp is the card when it's crashing? Is it a freeze up or just instant crash to desktop?
Thanks, will give it a shot, but I haven't changed my antivirus or anything like that.have you tried disabling your anti virus? sometimes the simplest of solutions work![]()
Will do after testing with a reset OC in a mo.Try without the ram you just installed.
Have you tried clocks lower than stock?
No, nor do I intend on trying clocks lower than stock just yet. I don't think its the CPU. It did it with my stable 4.7GHz overclock, it did it with my stable 4.6GHz overclock (using the same voltage as 4.6 just to ensure it was absolutely stable), and it's doing the same thing at stock clocks with auto voltages.
I recon it is either RAM, GPU or software. Hoping its software or RAM, but its likely to be the GPU.
Disabled all A/V shields, still happened.
Once again, i meant the GPU
Have you tried any of the older drivers I linked earlier?
sounds like overheating
Try with onboard or a 460![]()
