Gigabyte Mobo and 3770 OC little doubts
6 Oct 2012
Hi guys how are you?
First of all sorry if i'm posting at weong place and sorry dor my poor english, i'm from Brazil
So let's see if someone can help me
I have a Gigabyte GAZ77XD3H mobo and i had a stable overclock at 4.5 with my 3770k
Yesterday i made a bios update to the latest one the F17f (A beta bios) but i forgot to save or note my OC specs at bios and i forgot some steps
I can't remember if i used about 1.23 or 1.30 fixed vcore to stabilize at 4.5 i remember that i used the loadline calibration on Turbo, the CPU Pll at 1.5 ( Now i bumped to 1.65 just to be safe, should i go back to 1.5?) i disabled the c1 c3 and all this stuffs and disabled the tubo boost
So do you guys recommend me to do anything else in this OC? Should i make some other changes or that's all? I think the vcore i used was 1.23 but i can't really remember and i really don't wanna spend again a lot of time with stress tests, last time i spent about 19 hours prime and 20 passes Ibt max memory size
Any help will be nice, and just to you know guys i'm using a H100i push/pull cooling system
Thanks
follow that guide? its all there all the settings to make
post back if it blue screens with the 4.5ghz guide
Thanks
I`m doing everything correct but when running IBT the monitor goes black and i loose the video and after a couple of seconds the video comes back and i receive a message that the video driver has crashed cane back working with sucess
This not happens playing games or running some video benchs like heaven or 3dmark....
Any ideia?
Thanks
