Caporegime
- 11 Mar 2005
- Leafy Cheshire
Bear in mind though that the traffic density is significantly higher than it was in 1965.
Indeed, and thats why road craft is important.
Not really no, not on purpose. And certainly not a do gooder, just can't be bothered looking out for cameras and plod everywhere. I developed this strange concept of leaving a little earlier and making my car speedo thing read the same as the little signs you see dotted around the place. It's surprisingly easy.
I heard something a few weeks ago that explained why the speed limit won't be increased on motorways beyond the 70mph, despite numerous good arguments as to why it should, and it's to do with the Armco barriers, and the way they're designed to perform in a collision. They are basically strong enough to stop a vehicle up to a certain weight from breaching the barrier in a 45 degree impact at 75mph (sorry, I don't know any more specifics), and that is the main reason why motorway speed limits won't be increased, because the cost of replacing all the Armco across the UK's motorway network is prohibitive.
Armco is already being changed for concrete on sections of motorways, it will take a long time but armco is rubbish at stopping a truck.
Says not a doo gooder - posts make him look like one.
I see what you did there.![]()
No moral crusade here. You insinuated that everyone speeds. We don't.
Obviously a difficult concept, but it is technically possible to drive from a to b within the proscribed speed limits, I know mind blowing isn't it.
Yes, but only in accident black spots. Armco is much friendlier to the fleshy blobs inside a vehicle in the event of an accident as it deforms elastically to absorb a huge amount of the impact energy. Concrete...doesn't.
Everyone speeds, be it by only 1mph, not slowing down to 30 before the limit kicks in etc.
Unless you drive well below the speed limits, which btw makes you worse than someone who speeds slightly, it would be next to impossible to get through your entire driving career without a speeding infraction.
Why would driving below the MAXIMUM speed limit make him a worse driver than someone exceeding the MAXIMUM limit?
Driving is not just about car control its about observation, road placement etc. Thats why the driving test is not called a car handling test, its to demonstrate your ability to follow the prescribed rules and demostrate that capability on the road.
This is the whole problem with the poor attitude the majority of the population take to driving. Some people think its a target some that its there to be broken as they are an awesome driver and the limit is far too low for them etc etc. Fact is its a legal maximum limit which should only be adjusted DOWNWARDS if traffic or road conditions deem it to be unsafe.
IMO the whole 10% +2mph situation means people think its acceptable to brake the law. Its no more acceptable than any other law.
If your have any decent observation skills is very very easy to slow down before you enter a lower limit section. Anyone who struggles to achieve this is a poor driver.
Drivers who sit at 45 or 50mph on a national speed limit country road are more of a hazard than someone who drives at 65.
People become fedup sitting behind someone who seems unable to drive at what I would consider a more than reasonable speed I.e, 60mph, on a particular section of road in perfect conditions.
Yes it's a maximum limit, but if your unable to achieve close to this in perfect conditions then I would suggest that states far more about your ability or confidence to control a car.
As for the whole no more acceptable to brake the speed limit than any other law, rubbish, it might be law but some things are more sociably acceptable than others, I.e. it more acceptable to do 65 in a 60 than it is to kill someone with a knife.
I see far more poor driving from those who drive slower than I do from those who drive either at, or above the speed limit.
Seen a case a year ago where the guy was doing 71 in a 70 and got a £60 fine, I **** you not.
