Have you been to a shop and checked them side by side yet ??
Very true, but the HO memory is unified. If you stick a MSD card in the S4 you could run into confusion / difficulties as to where stuff is stored or installed to.
I like the fact that when i plug it into my PC i am presented with just a single 'drive' to manage.
confusion? -
Stuff is always installed on the internal SD.
I get where you're coming from, and see the positives of removable storage, but how many people end up sticking a 16 or 32gb card in there and never remove it? Quite a few i bet.
32gb is fine for my use as i use DropBox / Google Music / Google Drive etc so have pleanty of room.
For the sake of competition buy a One, or in future you might not have a choice to make![]()
The thing with the SD card is that you can't really use it for anything much. Most apps won't install to it unless you root, apps like Play music and Spotify won't cache to it etc.
