I have money! (Please spec me something nice)
31 May 2013
Ok, to cut a pretty long story short, I got a system from here a few weeks ago and things never really worked out with it, so I had to get a refund.
I then decided the best thing to do would be to build it myself, but in the meantime I started decorating which ate into my budget. What that means is that I'll need to leave out some components and buy them later when I'm paid (around 2 weeks).
In the meantime, I want to put together the rest of the computer so that it's useable until I buy the rest of the components.
This is what I don't need right now:
Graphics card
Additional Storage
Speakers/Headphones
Operating System
Monitor (Already have 1440p)
Basically I'll need everything else (including mouse and keyboard).
Requirements for the computer are that I'm a professional photographer, so I'm looking at either an i7 or an 8350 because I need the additional cores/threads. I'll also need 16GB ram.
I know that even an i5 will beat out an 8350 in most games, but at 1440p I think the graphics card I choose when I have the money for it will be the bottleneck anyway for games that I play. So i7 or 8350 for Lightroom and Photoshop is necessary, and I'd definitely be curious what kind of builds could be done to save me money with the 8350.
In addition, my other requirements are:
Mechanical Keyboard (Cherry MX Blue)
A mouse with a scroll wheel that's smooth and doesn't rattle horribly like a cheap bit of plastic (Razer Nagas are the worst for that).
Power supply that's quiet around 600 watts. Preferably Seasonic. (not doing SLI)
Case of preference is the Corsair 540
Budget for all of this is £900
Looking to pull the trigger next week on this.
Thanks for any suggestions!
Oh, just as an addition, I'd definitely consider the H80i/100i but not the refurbs. I like long warranty.
Here's an 8350 suggestion.
YOUR BASKET
1 x AMD Piledriver FX-8 Eight Core 8350 Black Edition 4.00GHz (Socket AM3+) Processor - Retail £161.99
1 x Gigabyte 990FXA-UD3 AMD 990FX (Socket AM3+) DDR3 Motherboard £113.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £113.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel kit (PV316G160C9K) £101.99
1 x CM Storm Quickfire TK Mechanical Keyboard - Blue Switch £72.98
1 x Logitech G700 Wireless Gaming Mouse (910-001759) £69.98
1 x XFX Pro 650W Core Edition '80 Plus Bronze' Power Supply £64.99
1 x Alpenföhn K2 Mount Doom CPU Cooler (Socket 775 / 1150 / 1155 / 1156 / 1366 / 2011 / AM2 / AM2+ / AM3 / FM1 / FM2) £59.99
Total : £774.90 (includes shipping : £12.50).
You could save money by getting the 8320 instead and overclocking it, but I get the feeling you won't want to do that. The XFX PSU is made by Seasonic.
Haswell i7 substitute:
YOUR BASKET
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
Total : £906.00 (includes shipping : £11.75).
I just realised though that the 8350 doesn't have onboard graphics, so I wouldn't be able to build it until I bought a graphics card in a few weeks time :(
You could get a second hand reasonable card for about £10 or so that would do better than Intel onboard graphics. The new very basic ones are £20-£25.
That's actually what I just looking at there mate. Would do as a back up as well if something went wrong with the GPU.
I have between now and Monday to consider what to get. Can't work on a laptop any longer.
If you want to take advantage of the lower priced AMD set up I'd go for the 8320 and overclock it - it's the same as an 8350, just clocked lower. It'd also mean if you want to upgrade the CPU to Steamroller next year you'd be spending less now.
Whatever you get is going to miles ahead of a laptop, anyway :)
YOUR BASKET
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £148.99
1 x AMD Piledriver FX-8 Eight Core 8320 Black Edition 3.50GHz (Socket AM3+) Processor - Retail £124.99
1 x Patriot Venom Red 16GB (2x8GB) DDR3 PC3-14900C10 1866MHz Dual Channel Memory Kit (PV316G186C0KRD) £113.99
1 x MSI 990XA-GD55 AMD 990X Chipset (Socket AM3+) DDR3 Motherboard £79.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £39.95
1 x Logitech G500 5700DPI Gaming Mouse (910-001262) £39.95
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £831.82 (includes shipping : £12.50).
Went with the 8320, as it will be very simple (and safe) to OC it to be faster than the 8350.
Included a fast/large SSD as it will speed up editing / saving large numbers of pictures by a lot.
The mouse sounds ideal, but I think you should read up about mice that will suit your needs before buying one.
Water cooling.
Plenty of budget left to get a used GPU.
You have a DVD ROM selected, a burner is not much more.
The Z87-D3HP is a better board than the HD3.
Your RAM choice is poor, you can get a 2133MHZ 16GB kit for the same money - http://www.overclockers.co.uk/showproduct.php?prodid=MY-066-PA&groupid=701&catid=8&subcat=1387 - all pointed out in earlier posts.
Just concerned about the RAM mate, the voltages are higher than 1.5 which I read was bad because the controller is on the processor itself. Will that be ok?
Also, if I make the changes you suggested, is everything else fine? (Especially Power supply compatibility?) Should take me to about a grand which I think I can manage tomorrow.
All performance ram (to clarify im referring to higher speeds) runs at 1.65v, ask 8pack if that voltage is safe and he will say yes.
Me as well as many other people run ram at 1.65v with the xmp profile on Sandybridge, Ivybridge and now Haswell without any problems.
Users also pump even higher voltages into there sticks to overclock the RAM even higher again.
