This will be my first build and after much research I have come up with the following which will go into my 600T case (modding required!) with an oc'd 4770k:
YOUR BASKET
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-TOP CSQ Value Combo £81.98
1 x Hardware Labs Black ICE Radiator SR1 240 £55.98
1 x XSPC RayStorm CPU WaterBlock (Intel) £51.98
1 x XSPC EX360 120mm Radiator - Black £49.99
1 x EK-RES X3 150 Reservoir £39.98
2 x Three Fan Bundle - Corsair SP120 Quiet Edition Fan 4 pin £31.99 (£63.98)
1 x ModMyMachine Shoggy Sandwich V2 for your Watercooling Pump £6.98
1 x XSPC HighFlex Hose 7/16" ID, 5/8" OD, 15.9/11.1mm, 2m, Red/UV Orange £5.98
1 x Mayhems Ultra Pure H20 Watercooling Fluid 1L £4.99
1 x Mayhems Fine Silver Kill Coil £4.5
1 x XSPC G1/4" T Fitting (Black Chrome) £3.95
3 x XSPC G1/4" 90° Rotary Fitting (Black Chrome) £3.49 (£10.47)
2 x XSPC G1/4" 45° Rotary Fitting (Black Chrome) £3.49 (£6.98)
10 x XSPC G1/4" to 7/16" ID, 5/8" OD Compression Fitting (Black Chrome) £2.99 (£29.90)
1 x XSPC G1/4" Plug (Black Chrome) £1.55
Total : £431.20 (includes shipping : £10.00).
I will be adding a suitable GPU to the loop when AMD's next gen show up, hence the lack of a GPU block and large number of rads just for a cpu!! Also I haven't included components for a potential fill port at the top.
My current layout concept is as follows:
Can anyone suggest any improvements???
A few questions:
1) I've also looked at bitspower fittings but they work out at an extra £50. Are they worth it?
2) I've chosen orange tubing at the moment over an orange dye. Any comments?
3) I've chosen a separate pump so I can easily isolate vibrations. Is this necessary or would a tube & pump or bay res & pump combo be fine?
As I said, this will be me first watercooled build so any advice and suggestions are really welcome!
YOUR BASKET
A few questions:
seems fine, just remember to watch the distance between the res and the mobo
