Hi guys & gals,
Looking at putting together a new system, to start with it's just going to be the tower that is replaced, but I plan on moving to a three monitor setup in the near future.
How well is a GTX 770 going to handle a three monitor setup? I had a look around online and it was a fairly mixed bag.
Would it be worthwhile spending more on the GTX 780, or even looking at future expansion with a second GTX 770 in SLi ? I was told it's safest to always aim for the one card solution where possible. Also, is there much benefit in the 4Gb GTX 770, the actual in-game results seem pretty similar between the 2 and 4 Gb options (again, from a few online comparisons).
What about the ATI options? Any of them worth checking out?
Currently using a single 1900x1200 monitor, and from what I can gather, any of the cards I'm looking at should handle a single monitor perfectly fine, maxing out most games. Multimonitor expansion seems to be the point where I need to be a bit more discerning in what I go for.
Either way I'm sure it'll be a massive step up from the XFX 8800 GTX I'm currently running, a beast in it's day, but struggles with newer games.
(currently planning on a Windows 7 system using an i5 4670, Z87 chipset motherboard and 8-16Gb ram, though I'll no doubt be posting other questions on those components in the coming days!)
tl;dr :
-Will the GTX 770 work well in a 3 monitor setup?
-GTX 780 or dual GTX 770 worthwhile if not?
-ATI worth looking at?
-Any practical advantage with a 4Gb 770 over a 2Gb 770?
Many thanks,
- Will
tl;dr :
Many thanks,
- Will
