*** ANOTHER BONKERS DEAL: MSI GTX 680 POWER EDITION ONLY £259.99 UNTIL 9AM TOMORROW!! ***
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK another crazy deal, but the catch is this price is only valid for TODAY ONLY until tomorrow at 9am, if the 20pc I have allocated sell out before close of business today I shall add another 20pc.
But this price shall be £289.99 tomorrow!
Remember this is the Power Edition GTX 680, it is essentially an MSI GTX 680 Lightning, the best GTX 680 ever built with huge potential. This card matches/beats most GTX 770's and is vastly better priced. Of course stock is limited so act quick. :D
MSI GeForce GTX 680 Power Edition 2048MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
This MSI GTX 680 Power Edition is almost identical to the record winning MSI GTX 680 Lightning, but here at OcUK we consider this card to be even better than the Lightning for two main reasons. The first being that this card cost far less, but the second that this card has Dual DVI connectivity.
Very limited stock and a crazy price!
Features:-
- GPU Reactor
- Xtreme Thermal
- Military Class III Components
- Triple Overvoltage: adjust the voltage of GPU, memory and VDDCI to unleash the potential of graphics card
- Offer 16 degree cooler and 6.7dB quieter than reference product
- Enhanced PWM Design: provide higher overclocking capability and better stability in peak load
Specification:-
- Core Clock: 1019MHz (GK104)
- Core Boost Clock: 1084MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2038MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 1x Dual-Link DVI-I, 1x DVI, 1x HDMI & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Card Dimensions: 270*111.15*38.75 mm
- 2x 8-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£359.99] Inc. VAT
Only £259.99 inc VAT.
ORDER NOW
Remember this prices ends tomorrow at 9am - You've got less than 24hrs to grab an epic bargain - GET YOUR WALLETS OUT! :D
Same here, I'm happy with my gpu setup.
I jumped at the chance to add another 660ti for sli, when they came down in price with the 760 launch...
Guys, if you have a 680, I'd jump at the chance for sli, huge value for money in this offer.
I got in early on mine. Thanks for another amazing deal OcUK!
A little advice please. I believe this isn't a reference card, so if I want to watercool I will need a custom block.
Does this card have the same layout as the MSI GTX 680 Lightning Edition?
If so will the following VGA blocks fit?
AquagraFX for GTX 680 Lightning
EK Water Blocks EK-FC680 GTX Lightning
Thanks!
