Just ordered the following parts:
MB: GA-Z77N-WIFI
CPU: i3770K
RAM: CML16GX3M2A1600C10
To update the following parts:
MB: Asus P5Q-Pro
CPU: Q9450
RAM: Cheap own brand DDR2 800mhz(because my original Reaper set died)
And pair with the existing parts:
SSD: Vertex 3
PSU: ATX 750w
GPU: 9800 GTX
Word to jargon ratio: 1.25
Now, needless to say, the case that housed the original ATX board may be a tad roomy for the new Mini-ITX board, and whilst it may be amusing to purchase the largest case you can with a nice window and stick a Mini-ITX board right in the middle of it, it rather defeats the point, and as such I'm looking for the smallest case I can reasonably fit the new bits in, preferably with the existing parts.
I've looked around and have seen that the aptly named Prodigy appears to be probably the most popular choice at the moment, however I believe that really that's still, like many of the ITX cases I've looked at, a tad on the large size unless you need a lot of HDDs. (I have 8.5TB of WD drives that will hopefully be getting pooled on the network for storage, as there seems to be a distinct lack of ITX boards with lots of sata ports, the most I've seen is 6).
My favourite case by far has to be the FT03-Mini.
Unfortunately that wont be able to take the ATX PSU.
And possibly not the 9800 GTX, I've been unable to find an exact length for my specific GPU and I'm not at home so I can't put amonarch sovereign maharajah rule to it.
It also doesn't have the best airflow and no option for increasing it.
I am interested to see what other Mini-ITX cases people recommend.
One other thing to bear in mind is that I would like to install an after-market CPU cooler eventually and overclock this system to see what it's capable of. I understand that this isn't the easiest thing to achieve due to the socket location on the particular board I've chosen and case clearance restraints can make it more difficult.
Final Word to Jargon ratio: 8.27
			MB: GA-Z77N-WIFI
CPU: i3770K
MB: Asus P5Q-Pro
CPU: Q9450
SSD: Vertex 3
PSU: ATX 750w
GPU: 9800 GTX
