What marks?
Are you sure that line wasn't there already? That's nothing to worry about.
You have no idea how relieved I am to hear you say that. I might have already been there, but the plastic cover never popped off properly when I pulled down the lever, and on the underside of the plastic cover there's 2 thin 1cm bits of plastic that come out of the bottom of it that I thought may have scraped along the processor. Hopefully everythings fine, but I don't even have a mouse and keyboard yet to properly test! Just installing the PSU and then the cooler and then I'll try and boot.
You're supposed to remove the plastic socket cover before you push the lever down, it just clips off. It won't have damaged it though from the sound of it.
Ah it's just every video I've watched says keep the cover on, and the manual says it too:
It's my first ever build, so pretty nervous. Just got the PSU hooked up so figuring out what cables go where, then I'll get the cooler on and try it.
First build getting ready to hit the power button is a nervous affair.
It boots. Thank ****. First build getting ready to hit the power button is a nervous affair. Unfortunately I have no mouse or keyboard or hard drive, so that's as far as it goes now!
Thanks for the reassurance, teppic.
Glad to hear, Hit the button on your first build is always scary.
