First off, sorry if this is in the incorrect section (i'm new here).
Thinking of buying an X51 with these specs:
Intel® Core™ i7-4770 Processor (8MB Cache, up to 3.9GHz with Turbo Boost Technology)
Windows 8 64bit, English
8GB1 Dual Channel DDR3 SDRAM at 1600MHz
1TB (64MB Cache) 7200 RPM SATA 3Gb/s
1.5GB GDDR5 NVIDIA® GeForce® GTX 660
After a haggling phone call to dell they offered it me for £885.
Then I tried to price this up based on a small form factor machine with the specs as close as possible, however it only comes in around £80 cheaper and will not look nearly as good as the X51's case.
Can anyone way up some pro's and cons for me??
the only issue that stands out to me is that the X-51's use power bricks which are rated at 330 watts which are the same as the M18x bricks.
Thanks in advance.
Thanks in advance.
