***** INSANITY WEEKEND AT OcUK: ASUS GTX 670's 2/4GB's AT LOWEST PRICES EVER!! *****
OcUK Staff
17 Oct 2002
OcUK HQ
Hi there
OK we've done some pretty epic GTX 670 and GTX 680 deals recently. Well I am now moving epic to pretty much borderline insane.
So we still have the incredible MSI Power Editions on THIS WEEK ONLY which are the absolute best cards if your looking for maximum OC potential, but for those of you who want an even better deal I can offer you the following:-
Asus GeForce GTX 670 DirectCU II OC Gamer 2048MB GDDR5 PCI-Express Graphics Card @ £189.95 inc VAT
DirectCU thermal design utilizes direct contact copper heatpipes so heat is dissipated efficiently, delivering a 20% cooler and vastly quieter performance than reference. 1085 MHz Boost clock for better performance and outstanding gaming experience. Acclaimed DIGI+ VRM has been applied via a massive power design that uses digital voltage regulators to minimize power noise by 30% and enhance power efficiency by 15%, widen the voltage modulation range, and improve overall stability and longevity by 2.5 times longer than reference.
Features:-
- TOP-selected 1058MHz core -78MHz higher than reference for smoother gameplay.
- Flattened copper heatpipes makes direct contact with the GPU surface so heat is dissipated efficiently, delivering a 20% cooler and vastly quieter performance than reference.
- Acclaimed DIGI+ VRM with 8-phase Super Alloy Power technology delivers precise digital power and enhanced durability for stable overclocking.
- GPU Tweak utility helps you modify and tune clocks (including new boost clock settings), power consumption targets, voltages, and fan performance via an intuitive interface
Specification:-
- Full length PCB, better for overclocking
- Core Clock: 980MHz (GK104)
- Core Boost Clock: 1058MHz
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1344
- Shader Clock: 1960MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 170 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- With FREE Diablo Gaming Mouse Mat
- Warranty: 3 Years
Was [£239.99] Inc. VAT
Only £189.95 inc VAT - Europes LOWEST PRICE
ORDER NOW
Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card @ £227.99 inc VAT
The new Asus GTX670-DC-4GD5 with Digi+ VRM for the ultimate power control and enhanced Overclocking comes with the Asus exclusive DirectCU II for up to 20% better cooling.
The GeForce GTX 670 graphics card taps into the powerful new GeForce architecture to redefine smooth, seamless, lifelike gaming. It's more than state-of-the-art technology and features. It's truly game-changing performance.
Faster:
- Innovative new GeForce architecture-designed to deliver faster, more power-efficient performance
- NVIDIA GPU Boost technology that dynamically maximizes clock speeds to push performance to new levels and bring out the best in every game
- The power to turn on lightning-fast antialiasing in a huge variety of games, automatically, with NVIDIA FXAA
- Support for new temporal antialiasing (TXAA) technique that delivers the ultimate combination of image quality and performance.
- The power of 3-way NVIDIA SLI® technology
Smoother:
- Ultra-smooth gaming experience with exciting new NVIDIA technology advancements
- NVIDIA Adaptive Vertical Sync adjusts VSync to current frame rates for maximum playability
Richer:
- NVIDIA® Surround™ multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display)
- Supercharged NVIDIA PhysX® and NVIDIA 3D Vision® performance
Features:-
- Double the reference video memory at 4GB takes your gaming to new levels of smooth.
Specification:-
- 20% cooler and Vastly quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS DIGI+ VRM technology with 6+2 phase Super Alloy Power for precise digital delivery and enhanced overclocked headroom. (compared to 4+2 phase in reference card)
- GPU Tweak utility allows you to tune graphics card performance and check card status via an intuitive interface
- Core Clock: 915MHz (GK104)
- Core Boost Clock: 980MHz
- Memory: 4096MB GDDR5
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
Was [£269.99] Inc. VAT
Only £227.99 inc VAT - Europes LOWEST PRICE!
ORDER NOW
Asus GeForce GTX 680 Direct CU II V2 2048MB GDDR5 PCI-Express Graphics Card @ £259.99 inc VAT
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans – making for low-noise and high-performance graphics cards.
Acclaimed DIGI+ VRM has been applied via a power design that uses digital voltage regulators to minimize power noise by 30% and enhance power efficiency by 15%, widen the voltage modulation range, and improve overall stability and longevity by 2.5 times longer than reference.
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- All new DirectCU thermal design utilizes five all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 10-phase Super Alloy Power technology delivers precise digital power and enhanced overclocking headroom.
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune boost clock, power target , and fan performance via an intuitive interface
Specification:-
- Core Clock: 1006MHz (GK104)
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Processing Cores: 1536
- Shader Clock: 2012MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- Warranty: 3 Years
Was [£286.99] Inc. VAT
Only £259.99 inc VAT - Europes LOWEST PRICE
ORDER NOW
Also these three cards are part of the NVIDIA Splintercell Blacklist promotion so you will also get this FREE Game worth £30-£40:-
NVIDIA: Splinter Cell Blacklist Game - FREE with NVIDIA GTX 660, 670, 680, 760, 770 & 780 graphics cards ONLY!! @ £39.95 inc VAT
The United States has a military presence in two-thirds of countries around the world. A group of 12 have had enough and initiate a terror ultimatum called the Blacklist - a deadly countdown of escalating terrorist attacks on U.S. interests. Sam Fisher is the leader of the newly formed 4th Echelon unit: a clandestine unit that answers solely to the President of the United States. Sam and his team must hunt down these terrorists by any means necessary and stop the Blacklist countdown before it reaches zero.
- FREE with GTX 660, 660Ti, 670, 680, 760, 770 and 780 for orders placed 09/07/2013 onwards.
- NOT FREE with GTX 690, Titan or any cards below GTX 660!!!
- You will get this game FREE automatically when you buy one of the qualifying cards - no need to add to your checkout seperately!!
Only £39.95 inc VAT.
FREE WITH ABOVE CARDS - You will automatically get this game, no need to add to your cart
In short this deal is unbeatable, so how can OcUK do such deals? Well it is simple I actually pro-actively search for great deals or actually request what is required to create great sales and get customers essentially getting their wallets out. As such we get results and can give you our customers such amazing deals. :)
Stock is due to land at OcUK Monday 12th August 2013
THIS INSANITY DEAL ENDS 9am Monday 12th August 2013 - So Pre-Order this weekend to avoid missing this deal price!
Hi there
Here is some more great deals for you from Asus as well:-
Asus GeForce GTX 780 Direct CU II OC 3072MB GDDR5 PCI-Express Graphics Card @ £539.99 inc VAT
The newly arrived ASUS GTX780-DC2OC-3GD5 ships with 28nm GPU and 3GB GDDR5. To fully harness the power of new GPU technology, ASUS GTX780-DC2OC-3GD5 built with ASUS exclusive DirectCU II design featuring a 40% more efficient 10mm copper heat-pipe, 2.2X larger dissipation surface are and unique CoolTech fan that ensures 30% cooler and up to 3X quieter performance than reference. For enhanced overclocked headroom and gaming experience, ASUS redesign GTX780 with DIGI+ VRM offering precise digital delivery for better software overclocking stability. For enhanced overclocked headroom, ASUS GTX780-DC2OC-3GD5 uses 8+2 phase power design in Super Alloy Power technology, compared to 6+2 phase power design in reference card. In addition, GPU Tweak utility helps users modify and tune boost clock speed, power target, temperature target and fan performance via an intuitive interface. This card uses PCI Express 3.0 as the standard interface, doubling the data bandwidth of PCI Express 2.0. The power of ASUS GTX780-DC2OC-3GD5 also supports NVIDIA® Adaptive VSync technology and 3D Vision® surround™. ASUS GTX780-DC2OC-3GD5 provides fantastic gaming experience!
Features:-
- 941MHz Boost Clock
- 30% cooler and 3X quieter performance with ASUS exclusive DirectCU II thermal solution
- ASUS uses 8+2 phase power design in DIGI+ VRM and Super Alloy Power technology for precise digital delivery and enhanced overclocked headroom.
Specification:-
- GPU: GeForce GTX 780
- Core Base Clock: 863 MHz
- Core Boost Clock: 941 MHz
- Memory Clock: 6008 MHz
- Memory Size: 3072MB GDDR5
- Bus Type: PCI Express 3.0
- Memory Bus: 384-bit
- CUDA Cores: 2304
- Memory type: 64Mx32
- DirectX 11.1: Yes
- DVI Port: DVI-I /DVI-D
- DisplayPort: Yes
- HDCP: Yes
- HDMI: Yes
- Warranty: 3yr
Was [£599.99] Inc. VAT
Only £539.99 inc VAT.
ORDER NOW
Asus GeForce GTX 770 DirectCU OC 2048MB GDDR5 PCI-Express Graphics Card @ £329.99 inc VAT
The next generation GeForce GTX 770 is a high-performance graphics card designed from the ground up to deliver super-fast, smooth and quiet gaming. It features the most advanced technology innovations, engineering and features to deliver spectacular performance in today's most demanding games.
Features:-
- Innovative new GeForce architecture, designed to deliver faster, more power-efficient performance
- The power to turn on lightning-fast anti-aliasing in a huge variety of games, automatically, with NVIDIA FXAA
- NVIDIA 3D Vision® Surround multi-monitor gaming on a single GPU (three gaming monitors plus one accessory display) - for the first time ever
- New 28nm process means cooler, quieter and far superior overclocking potential than previous generation graphics cards
Specification:-
- Core Clock: 1058MHz (GK104)
- Core Boost Clock: 1110MHz
- Memory Clock: 7010MHz (Effective)
- Shader Clock: 2220MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Lower power consumption (Maximum consumption 230 watts at stock speed)
- 1x 8-Pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£359.99] Inc. VAT
Only £329.99 inc VAT.
ORDER NOW
Asus GeForce GTX 760 DirectCUII OC 2048MB GDDR5 PCI-Express Graphics Card @ £203.99 inc VAT
GeForce® GTX 760 is the new weapon of choice for gamers—a powerful graphics card that gives you fast, smooth, quiet performance in all your favorite titles. It’s packed with next-gen technology innovations, engineering, and features that let you crank up the settings and resolutions in graphics-intensive games like Splinter Cell: Blacklist.
Take hyper-realistic gameplay to a whole new level with NVIDIA GPU Boost 2.0 for max clock speeds, PhysX® and TXAA™ for great graphics, and NVIDIA® SHIELD™ compatibility for incredible portable gaming. Plus, instantly access the latest game-ready drivers automatically—the day a game launches—and optimize settings with one click using GeForce Experience™. Even auto-record all your greatest gaming moments with NVIDIA ShadowPlay.
This is serious equipment for the serious gamer.
Specification:-
- Core Boost Clock: 1072MHz
- Processing Cores: 1152
- Shader Clock: 2116MHz
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- 1x 8-pin & 1x 6-Pin PCI-E Connectors required
- Warranty: 3 Years
Was [£215.99] Inc. VAT
Only £203.99 inc VAT.
ORDER NOW
Asus GeForce GT 610 SILENT Low Profile 1024MB GDDR3 PCI-Express Graphics Card @ £29.99 inc VAT
The exclusive alloyed components helps boost performance by reducing power loss, enhancing durability and achieving cooler operation. The chokes’ concrete core eliminates the buzz sound in full load while the capacitors assure a 50,000 hours lifespan - equivalent to 2.5 times longer than traditional capacitors.
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy. ASUS low profile HTPC and multimedia-focused graphics cards are optimized for smooth 1920x1080 streaming and Blu-ray 3D.
Features:-
- Exclusive 0dB thermal design dissipates heat efficiently without any noise
- ASUS low profile HTPC and multimedia-focused graphics cards are optimized for smooth 1920x1080 streaming and Blu-ray 3D
- Full HD multimedia entertainment with DX11 and HDMI support
Specification:-
- CUDA Cores: 48
- Core Clock (MHz): 810
- Boost Core Clock (MHz): n/a
- Processor Clock (MHz): 1620
- Memory Amount: 1GB DDR3
- Memory Interface: 64-bit
- Memory Clock (MHz): 1200MHz effective
- Memory Bandwidth(GB/sec): 8
- Texture Fill Rate (billion/sec): 13 / 6.5
- Direct X 11
- Outputs: Dual DVI-I / HDMI / VGA
- Power Connectors: None
- TDP: 29W
- 3yr Warranty
Was [£31.99] Inc. VAT
Only £29.99 inc VAT.
ORDER NOW
Asus GeForce GT 620 Low Profile 1024MB GDDR3 PCI-Express Graphics Card @ £39.95 inc VAT
Unique fan design dissipates heat efficiently while extending a graphic card’s lifespan by 25%* through increased dust and particle resistance. Exclusively-formulated alloy components boost performance by reducing power loss, enhancing durability, and achieving cooler operation. Choke concrete cores eliminate buzzing sound under full load while capacitors assure a 50,000-hour lifespan: equivalent to 2.5 times longer than traditional capacitors.
Features:-
- Resists dust and particles for 25% longer graphics card longevity
- Premium alloys in power delivery components defeat heat for cards that run 15% faster and last 2.5 times longer than reference.
- GPU Tweak helps you modify clock speeds, voltages, fan performance and more, all via an intuitive interface.
Specification:-
- CUDA Cores: 96
- Core Clock (MHz): 700
- Processor Clock (MHz): 1400
- Memory Bandwidth(GB/sec): 5.3
- Texture Fill Rate (billion/sec): 13 / 11.2
- Direct X 11
- TDP: 49W
- 3yr Warranty
Was [£41.99] Inc. VAT
ORDER NOW
Asus GeForce GT 630 2048MB GDDR3 PCI-Express Graphics Card @ £53.99 inc VAT
Every PC deserves great graphics. NVIDIA GeForce GT 600-series graphics cards deliver premium multimedia performance-every time. Trust NVIDIA GeForce GT 630, 620, and 610 dedicated graphics for a faster, more immersive experience in your favorite applications.
Features:-
- Pump up graphics performance with Super Alloy Power delivering a 15% performance boost, 2.5 longer lifespan and 35°C cooler operation
- Dust-proof Fan design increases particle resistence and extends card lifespan by up to 25% longer than reference.
- GPU Tweak utility helps you modify and tune clock speeds, voltages, and fan performance via an intuitive interface.
Specification:-
- CUDA Cores: 96
- Memory Amount: 2GB DDR3
- Memory Interface: 128-bit
- Memory Clock (MHz): 1800MHz
- Memory Bandwidth(GB/sec): 25.6
- Texture Fill Rate (billion/sec): 13 / 13
- Direct X 11
- TDP: 65W
- 3yr Warranty
Was [£55.99] Inc. VAT
Only £53.99 inc VAT.
ORDER NOW
Asus GeForce GT 630 4096MB GDDR3 PCI-Express Graphics Card @ £65.99 inc VAT
Features:-
Specification:-
- CUDA Cores: 96
- Memory Amount: 4GB DDR3
- Memory Clock (MHz): 1100MHz
- Direct X 11
- TDP: 65W
- 3yr Warranty
Was [£69.95] Inc. VAT
Only £65.99 inc VAT.
ORDER NOW
Asus GeForce GT 210 SILENT Low Profile 1024MB GDDR3 PCI-Express Graphics Card @ £19.99 inc VAT
Silent passive cooling runs 0dB quiet, perfect for hushed gaming and multimedia joy. ASUS low profile HTPC and multimedia-focused graphics cards are optimized for smooth 1920x1080 streaming and Blu-ray 3D. Effectively blocks 66% radiations to protect user's health and improve graphics clarity.
Features:-
- Exclusive 0dB thermal design dissipates heat efficiently with no noise generated
- Ideal for home theater PCs and multimedia centers with its low profile, high-efficiency, low-consumption design
- Native HDMI on board for full HD 1080p entertainment
- Enhanced durability and protection with GPU Guard and EMI Shield
Specification:-
- Core Clock: 589MHz
- Memory: 1024MB GDDR3
- Memory Clock: 1200MHz (Effective)
- Memory Interface: 64-Bit
- Processing Cores: 16
- Shader Clock: 1238MHz
- Bus Type: PCI-Express 2.0
- Display Connectors: VGA, Dual-Link DVI-I & HDMI
- HDCP Capable
- DirectX 10 Support
- OpenGL 3.1 Support
- CUDA Enabled
- Warranty: 3 Years
Was [£22.99] Inc. VAT
Only £19.99 inc VAT.
ORDER NOW
Asus Google Nexus 7 16GB Tablet PC @ £199.99 inc VAT
The clean, simple design features a slim body, a thin bezel and a soft-touch, matte back cover. It sits comfortably in the palm of your hand while the bright, beautiful 7-inch display brings entertainment to life.
At just 0.64lbs (290g), the all-new Nexus 7 is light enough to take anywhere and fits easily in bags, backpacks, and even back-pockets. With up to 9 hours of HD video playback and 10 hours of web browsing or e-reading, there's plenty of juice to get you through the day, and built-in wireless charging means you can charge, grab, and go.
The world's highest-resolution 7-inch tablet puts over 2.3 million pixels in the palm of your hand. With 323 pixels packed into every inch, you can read text that’s sharper than a printed page, see images more vivid than the highest quality photo magazine, and watch movies come to life in vibrant full HD.
Nexus 7 is made by ASUS and packs a serious punch. With a quad-core Qualcomm® Snapdragon™ S4 Pro processor and 2GB of RAM, everything runs faster. Plus, high-performance rendering ensures 3D graphics are smooth and dynamic.
Nexus 7 features stereo speakers and Surround Sound powered by Fraunhofer (creators of the MP3 format) so you get rich and immersive audio. Hear it all more clearly with finely tuned volume boost technology that makes dialog and sound crisp and easier on the ears.
Video conferencing and face-to-face chats with family and friends are more seamless than ever. 1.2MP front and 5MP auto-focus rear cameras and the f/2.4 aperture allows you to capture every moment with rich photos or crisp Full HD video.
Nexus 7 comes loaded with your favorite Google apps – like Chrome, Gmail, YouTube, Hangouts and Google Now – so you can browse, watch, share and stay connected wherever you go. And because Google apps are designed for the cloud, everything is simple and works seamlessly across your phone, tablet and computer. Now you have all the stuff you need, when you need it.
Nexus 7 is the first tablet to ship with Android 4.3, the latest version of the world's most popular mobile operating system so it's fast, funand easy to make your own. Share your tablet with friends and family – each person has a separate customizable space, including personal homescreen, wallpaper, apps, storage, and more. You can also manage access to apps and content to create an experience that’s appropriate for each member of the family.
Nexus 7 is great for gaming and with favorites like Prince of Persia, Asphalt 8, and Riptide GP 2, you can tilt, tap, and touch your way to the top. The brand new Play Games app also lets you track your achievements, play with (or against) friends and gamers around the world, and discover new exciting games. And with an ever-expanding number of tablet-optimized apps like Flipboard, Expedia, or The Fancy, you’ll find all the apps you love, and love the many new apps you find.
Kick back with the world's largest collection of eBooks, listen to millions of music tracks with All Access, and immerse yourself with thousands of movies and TV shows on Google Play
Features:-
- Over 2.3 million pixels packed into a 7-inch display with an ultra-high 323ppi for incredible visuals in full HD
- Slim new design increases comfort and portability, narrow bezels make it easy to hold in one hand
- Designed for portability: weighing only 290g with an ultra-thin 8.65mm profile
- Quad-core performance: Qualcomm Snapdragon S4 Pro processor and 2GB RAM for smooth and responsive performance
- Photos and video with dual HD cameras: 1.2MP front and 5MP rear
- Cinematic stereo surround: Fraunhofer Cingo mobile audio technology for 5.1 virtual surround sound
- Now thinner, lighter, and faster – Nexus 7 brings you the perfect mix of power, portability and features
- The world’s sharpest 7-inch tablet screen.
Specification:-
- Qualcomm Snapdragon S4 Pro 8064 1.5Ghz,
- L2 2MB Cache
- Quad-core
- 16GB eMMC Storage
- 2GB Memory
- Operating system: Android Jelly Bean 4.3
- 7" LED backlight IPS panel
- Corning Fit glass
- Resolution: Full HD 1200 x 1920
- Bluetooth 4.0
- Wifi: 802.11a/b/g/n
- Warranty: 1yr
Only £199.99 inc VAT.
ORDER NOW
Asus Google Nexus 7 32GB Tablet PC @ £239.99 inc VAT
Features:-
Specification:-
- L2 2MB Cache
- Quad-core
- 32GB eMMC Storage
- 2GB Memory
- Corning Fit glass
- Bluetooth 4.0
- Warranty: 1yr
Only £239.99 inc VAT.
ORDER NOW
A real good reason to spend with OcUK this weekend! :D
Hi there
And here is some great monitors deals:-
Asus VX239H 23" Widescreen Super-Slim Bezel LED Monitor - Black @ £179.99 inc VAT
Inspired by millennia of artistic legacy, the new VX239H sports an elegant and precision-crafted sundial design. The VX239H features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It’s ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while dual HDMI/MHL ports offers extensive connectivity options.
VX239H comes with rich connectivity including dual HDMI/MHL ports and D-sub so that users could easily share and view MHL mobile devices* content on a much bigger screen, as well as charging MHL devices simultaneously. Also connect VX239H with Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
VX239H features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology – delivering improved color accuracy plus increased energy efficiency.
With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VX239H augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals. ASUS includes its exclusive QuickFit Virtual Scale feature with the VX239H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:-
- Full HD AH-IPS LED display with 178° wide-view angle in frameless design for edge-to-edge brilliance
- Featuring dual HDMI/MHL ports for multi device connections and MHL devices battery charging
- Ultra-slim, ergonomic design with sturdy sundial-inspired stand
Specification:-
- Panel Size: 23.0" 16:9
- Panel Type: AH-IPS
- Resolution: 1920x1080
- Pixel Pitch: 0.2652mm
- Brightness: 250cd/m2
- Contrast Ratio: 80,000,000:1
- Viewing Angles: 178/178
- Response Time: 5ms
- Colours: 16.7M
- Speakers: 1W x 2 Stereo RMS
- Connectivity: HDMI/MHL x2, D-Sub
- Dimensions with Stand: 532.9 x 389.8 x 210.1mm
- Weight: 3.8kg
- Warranty: 3yr
Was [£185.99] Inc. VAT
Only £179.99 inc VAT.
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £149.99 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was [£161.99] Inc. VAT
Only £149.99 inc VAT.
ORDER NOW
Asus VG248QE 24" Widescreen 144Hz 1ms Gaming LED Monitor - Black @ £289.99 inc VAT
Latest Asus VG248QE is a state of the art 24" gaming monitor with industry leading features such as 144Hz refresh rate for super fluidity in the latest games. 3D Vision 2.0 support, so bring your games to life with NVIDIA 3D Vision (Emitter & Glasses NOT included). Plus the latest GamePlus technology, an Asus-exclusive GamePlus hotkey with Aimpoint and Timer functions in FPS and RTS games. To ensure games are ghost free the Asus also sports one of the industries fastest response times with just 1ms.
Features:-
- Gameplus: ASUS-exclusive GamePlus hotkey with Aimpoint & Timer functions in FPS and RTS games
- Ultra smooth action with 144Hz rapid refresh rate and 1ms (GTG) tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- A comfortable viewing with ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and DisplayPort
- VG248QE supports NVIDIA 3D Vision 2 through connection of Dual-link DVI.
- Suggest purchasing the additional NVIDIA 3D Vision 2 Kit for immersive 3D enjoyment, also available from OcUK!
Specification:-
- Panel Size: Wide Screen 24.0" 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes
- Brightness(Max): 350 cd/m
- ASUS Smart Contrast Ratio (ASCR): 800000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms (Gray to Gray)
- Display Colors: 16.7M
- Trace Free Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 2W x 2 Stereo RMS
- Signal Input : HDMI , Dual-link DVI-D (support NVIDIA 3D Vision), DisplayPort
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Power Consumption(Typical): <65W
- Power Saving Mode: <1W
- Power Off Mode: <1W
- Voltage: 100-240V, 50/60Hz
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Warranty: 3yr
Was [£311.99] Inc. VAT
Only £289.99 inc VAT.
ORDER NOW
Asus SonicMaster MX299Q 29" Ultra Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers @ £419.99 inc VAT
With a display area equivalent to that of two 17-inch (5:4 aspect ratio) monitors placed alongside each other, the ASUS Designo Series MX299Q Ultra-wide 21:9 Cinematic monitor has a display area 33% wider than a Full HD monitor.
The 21:9 aspect ratio gives you more screen real estate for working with multiple windows side-by-side as you would with a secondary display.
The 2560 x 1080 resolution also means there are no black bars above and below the image when watching widescreen 2.35:1 movies and gamers can also enjoy games in immersive cinematic widescreen.
The LED-backlit AH-IPS display has extremely accurate color reproduction that makes the MX299Q ideally suited for both professional and home use. A 178-degree wide viewing angles also ensures minimal color distortion for enhanced screen sharing.
The MX299Q features an ultra-slim profile measuring just 16.4mm at its thinnest point. ASUS Designo Series MX monitors have received numerous design accolades that include the 2012 Japan Good Design Award. The MX299Q also won a 2013 CES Innovations Awards in the Video Displays category.
The ASUS Designo Series MX299Q Ultra-wide 21:9 Cinematic monitor features ASUS SonicMaster audio technology, co-developed with Bang & Olufsen ICEpower®. A combination of advanced audio hardware and professional audio processing, SonicMaster refines every acoustic detail to deliver crystal clear sound with richer, more distinct vocals and wide frequency range. The MX299Q has an embedded Bang & Olufsen ICEpower MobileSound 3 chip that delivers incredible audio fidelity through the two built-in 3-watt stereo speakers for rich and satisfying sound.
Considering its slender form factor, adding powerful audio to MX299Q presented a challenge. Nonetheless, the display features up to 32mm diameter speakers for greater and smoother sound impact with better bass performance. It also offers a resonance chamber of up to 100cc, expanding monitor sound range to new extremes.
A built-in amplifier powers speaker sound reproduction, just like a car engine with more horsepower means better performance can be attained. MX299Q uses up to 5W amplifiers per channel, with speakers embedding large rare earth magnets to generate more powerful and striking sound.
Features:-
- Ultra-wide 21:9 2560 x 1080 resolution LED display with a frameless, edge-to-edge design for pristine cinematic experience and enhanced productivity
- AH-IPS display with 178° wide-view angle for high-quality visual clarity and minimal color distortion
- ASUS SonicMaster Technology, co-developed with Bang & Olufsen ICEpower®, for audio playback that stays true to the source
- DisplayPort, HDMI/MHL, and Dual-link DVI ports for multi-device connectivity
Specification:-
- Panel Size: 29" Super Wide 21:9
- Resolution: 2560x1080
- Brightness: 300cd/m2
- Colours: 16.7M
- Speakers: 3W x 2 Stereo RMS with Bang & Olufsen ICEpower
- Connectivity: HDMI/MHL, Displayport, Dual-Link DVI-D
- Dimensions: 700.2 x 391 x 215.1mm
- Weight: 5.5kg
- Warranty: 3yr
Only £419.99 inc VAT.
ORDER NOW
Asus VE278N 27" Widescreen LED Multimedia Monitor - Black @ £199.99 inc VAT
This large 27"W LCD monitor indulges your visual senses with Full HD 1920 x 1080 resolution, 50,000,000:1 ASUS Smart Contrast Ratio and 5ms quick response time.
The big 27" 16:9 widescreen with Full HD quality (resolution: 1920x1080) delivers the best details of the high definition content to bring more pleasure while playing games or watching movies. Its optimized color performance enhances your high-definition video entertainment, graphics-intensive creative tasks, productivity applications, gaming enjoyment and Internet surfing.
Be captivated by stunning images with ASUS Smart Contrast Ratio (ASCR) technology that boosts the display´s contrast ratio to an astonishing 50,000,000:1
The ASUS-exclusive QuickFit built in the monitor provides real-size document, photo, and grid mode on top of the operating windows on the screen. It can activated via a hotkey on monitor and used as a guide to accurately view and edit photos.
Features:-
- Display Panel Size : 27.0"(68.6cm) 16:9 Wide Screen
- Pixel Pitch : 0.311mm
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- Response Time : 5ms (Gray to Gray)
- Picture-in-Picture
- Audio Features Stereo Speakers : 3W x 2 Stereo RMS
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : D-Sub, DVI-D
- Signal Frequency Analog Signal Frequency : 24~92 KHz(H)/ 50~85 Hz(V)
- Digital Signal Frequency : 24~92 KHz(H)/ 50~85 Hz(V)
- Power Consumption Power Consumption < 45 W
- Power Saving Mode < 2 W
- Tilt : +20°~-5°
- Dimensions Phys.Dimension(WxHxD): 643x445.6x220mm
- Box Dimension(WxHxD): 732x560x176mm
- Weight Net Weight (Esti.): 6.5 kg
- Gross Weight (Esti.): 9.8 kg
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Regulation Approval
- Warranty: 3yr
Was [£209.99] Inc. VAT
ORDER NOW
Asus VN279QLB 27" Widescreen Super-Slim Bezel LED Monitor - Black @ £299.99 inc VAT
The ASUS VN series features compact dimensions—this 27” display has a super narrow bezel of just 0.8cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN279QLB is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution .
VN279QLB leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including DisplayPort, HDMI/MHL and D-sub inputs
The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey
VN279QLB adopts 178°(H) / 178°(V) ultra wide viewing angle AMVA+ panel that eliminates color shift on your screen no matter where and how you look at it.
With 100,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN279QLB enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
ASUS includes its exclusive QuickFit Virtual Scale feature with the VN279QLB , allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
The ergonomically-designed VN279QLB Monitor comes with swivel, tilt, pivot, and height adjustments for ideal viewing position.
VN279QLB comes with rich connectivity including 2 X USB 3.0, DisplayPort. HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
Features:-
- Ideal for a multi-screen solution with a super narrow frame and an ergonomic stand
- Best for work and play with Full HD 1080p visual quality and 178° ultra wide viewing angle AMVA+ panel
- ASUS VividPixel Technology for crystal-clear and detail-oriented enjoyment
- MHL (Mobile High-Definition Link) function for Enhanced Viewing from Mobile to Monitor
- Ergonomic design for tilt, pivot, swivel and height adjustments ensure a comfortable viewing experience
Specification:-
- Panel Size: 27.0" 16:9
- Pixel Pitch: 0.311mm
- Contrast Ratio: 10000000:1
- Viewing Angle: 178/178
- Colours: 16.7M
- Speakers: 2W x 2 Stereo RMS
- Connectivity: HDMI/MHL, D-Sub, DisplayPort
- USB Hub
- Dimensions with stand: 619.2 x 526 x 225.5mm
- Weight: 6.1kg
- Warranty: 3yr
Was [£319.99] Inc. VAT
Only £299.99 inc VAT.
ORDER NOW
Asus VX279Q 27" Widescreen Super-Slim Bezel LED Monitor - Black @ £269.99 inc VAT
Inspired by millennia of artistic legacy, the new VX279Q sports an elegant and precision-crafted sundial design. The VX279Q features an edge-to-edge frameless panel with 178° ultra-wide viewing angle AH-IPS A+ panel for incredible visuals. It’s ultra-slim and ergonomic design can be tilted to provide you comfortable viewing experiences, while HDMI/MHL ports offers extensive connectivity options.
VX279Q features a 16:9 aspect ratio LED-backlit AH-IPS A+ panel with a 178° wide-view angle that minimizes color shift on both horizontal and vertical planes to ensure quality visuals from almost any direction. AH-IPS is the latest in IPS technology – delivering improved color accuracy plus increased energy efficiency.
With ASUS Smart Contrast Ratio (ASCR) of 80,000,000:1 and 250cd/m² brightness, VX279Q augments display contrast and sharpness by adjusting backlighting luminance to achieve the deepest blacks and brightest whites for truly lifelike visuals.
ASUS includes its exclusive QuickFit Virtual Scale feature with the VX279Q , allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:-
- Featuring DisplayPort, D-Sub, and HDMI/MHL ports for multi device connections
Specification:-
- Panel Size: 27" 16:9
- Colours: 16.7M
- Speakers: 1.5W x2 Stereo RMS
- Dimensions with stand: 622.6x441.3x210.1mm
- Weight: 4.6kg
- Warranty: 3yr
Only £269.99 inc VAT.
ORDER NOW
Asus PB278Q 27" Professional LED Multimedia Monitor - Black @ £499.99 inc VAT
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! New premium 16:9 wide-format PB278Q LED displays afford 178° wide viewing angles for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true “what you imagine is what you create” power. HDMI 1.4, DisplayPort 1.2, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
The PB278Q features a 16:9 aspect ratio and a LED-backlit 27” WQHD display that provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals – equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
The screen’s 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278Q, power and energy savings are no longer compromised, while better visuals are assured.
The ASUS PB278Q provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27” full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278Q is undoubtedly your best choice for work and play.
The PB278Q features a host of connectivity options that include HDMI 1.4, DisplayPort 1.2, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the PB278Q enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
Driven by a precision color engine that automatically analyzes and determines the nature of your current task, Splendid™ Video Intelligence Technology adjusts display parameters accordingly to ensure color accuracy and image fidelity. Six preset modes (scenery, theater, sRGB, standard, and two user-customizable modes) can be quickly selected via a designated hotkey.
The PB278Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
Features:-
- Stereo Speakers: 3W x2
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 8000000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI 1.4, 1x DisplayPort 1.2
- 8-in-1 Card Reader
- VESA Compliant (100x100)
- Dimensions: (WxHxD): 643x552.3x218 mm
- Weight: 8.80kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
- Product Review: http://www.tftcentral.co.uk/reviews/asus_pb278q.htm
Was [£539.99] Inc. VAT
Only £499.99 inc VAT.
ORDER NOW
Asus VG278HR 27" TRUE 144Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £479.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 144 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 144Hz refresh rate and 2ms tracer-free
- Ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Full HD 1080P : Yes
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was [£499.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
And here is some ROG gaming boards to get your teeth in to with the awesome Sabertooth! Should make for a nice set up with one of those awesome DirectCUII cards ;)
Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £169.99 inc VAT
"The Republic of Gamers consists only the best of the best. We offer the best hardware engineering, the fastest performance, the most innovating ideas, and we welcome the best gamers to join in.
In the Republic of Gamers, mercy rules are only for the weak, and bragging rights means everything. We believe in making statements and we excel in competitions. If your character matches our trait, then join the elite club, make your presence felt, in the Republic of Gamers."
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset features both the USB 3.0 & SATA6Gb technology for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
CPU
- LGA1150 socket for 4th Generation Intel® Core™ i7/ i5/ i3, Pentium® / Celeron® Processors
- Support 22nm CPU
- Support Intel® Turbo Boost Technology 2.0
- * The Intel® Turbo Boost Technology 2.0 support depends on the CPU types.
- ** Refer to www.asus.com for Intel CPU support list
Chipset
- Intel® Z87 Express Chipset
Memory
- Dual channel memory architecture
- 4 x DIMM, max. 32GB, DDR3 3000 (O.C.)/DDR3 2800(O.C.)/2666(O.C.)/2600(O.C.)/2500(O.C.)/2400(O.C.)/2200(O.C.)/2133(O.C.)/2000(O.C.)/1866(O.C.)/1800(O.C.)/1600/1333 MHz, non-ECC, un-buffered memory
- Support Intel® Extreme Memory Profile (XMP)
- * Hyper DIMM support is subject to the physical characteristics of individual CPUs.
- ** Please refer to Memory QVL (Qualified Vendors List) for details.
Expansion Slots
- 2 x PCI Express 3.0/2.0 x16 slots (Red, single at x16 or dual at x8/x8 mode)
- 1 x PCI Express 2.0 x16 slot (Black, max. at x4 mode)*
- 3 x PCI Express 2.0 x1 slot**
- * The PCIe 2.0 x16 slot (PCIEX4_3) shares bandwidth with PCIe 2.0 x1 slots. The default setting is x1 mode.
- ** The PCIe 2.0 x1 slots (PCIEX1_1/2/3) will be disabled when PCIe 2.0 x16 slot (PCIEX4_3 ) operates under x4 speed.
VGA
- Integrated Intel® HD Graphics Processor
- HDMI with max. resolution 4096x2160@24Hz / 2560x1600@60Hz
- Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
- Multi-GPU Support NVIDIA® SLI™ / AMD CrossFireX™ Technology
Storage
- Intel® Z87 Express Chipset:
- 6 x SATA 6Gb/s ports
- Intel® Rapid Storage Technology 12 supports RAID 0, 1, 5 and 10
- Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
- ASMedia® SATA 6Gb/s controller:
- 2 x SATA 6Gb/s ports**
- * The supported functions depends on the CPU installed.
- ** These SATA ports are for data hard drives only. ATAPI devices are not supported.
LAN
- 1 x Intel® I217-V Gigabit LAN Controller
Audio
- ROG SupremeFX Audio 8-Channel High Definition Audio
- SupremeFX Shielding Technology
- ELNA® Premium Audio Capacitors
- Content Protection for Full Rate lossless DVD Audio, Blu-ray DVD, and HD-DVD audio content playback
- Jack-detection, Multi-streaming, Front Panel Jack-retasking
- Optical S/PDIF out port at back panel
Audio Feature:
- Sonic Radar
- DTS Connect
USB
- 6 x USB 3.0 ports (4 ports at back panel [blue], 2 ports at mid-board [red])*
- 8 x USB 2.0 ports (4 ports at back panel; 4 ports at mid-board)**
- * Support ASUS USB 3.0 Boost, UASP standard on the Intel native USB 3.0 is only supported under Windows® 8.
- ** 2 x USB2.0 ports at mid-board shares with ROG extension (ROG_EXT) port.
ROG Exclusive Features
- Extreme Engine Digi+ III
- Full digital 8+2 phase CPU/DRAM power
- NexFET™ Power Block MOSFET
- 60A BlackWing Chokes
- 10K Black Metallic Capacitors
- ROG GameFirst II
- ROG RAMDisk
- CPU Level Up
- UEFI BIOS features :
- Extreme Tweaker
- Tweakers' Paradise
- ROG SSD Secure Erase
- BIOS Print
- GPU.DIMM Post
- O.C. Profile
- ROG Pulse
Special Features
- ASUS Dual Intelligent Processors 4
- 4-Way Optimization Tuning Key, consolidating DIGI+ Power Control, TPU, EPU, and Fan Xpert 2
ASUS Exclusive Features
- AI Suite III
- USB 3.0 Boost
- USB Charger+
- AI Charger
- Disk Unlocker
- ASUS EZ DIY
- USB BIOS Flashback
- ASUS CrashFree BIOS 3
- ASUS EZ Flash 2
- ASUS C.P.R.(CPU Parameter Recall)
- ASUS Q-Design
- ASUS Q-Code
- ASUS Q-Shield
- ASUS Q-Connector
- ASUS Q-LED (CPU, DRAM, VGA, Boot Device LED)
- ASUS Q-Slot
- ASUS Q-DIMM
Back I/O Ports
- 1 x PS/2 keyboard/mouse combo port
- 4 x USB 2.0 ports
- 1 x USB BIOS Flashback button
- 1 x Optical S/PDIF out
- 1 x HDMI port
- 4 x USB 3.0 ports [blue]
- 1 x LAN (RJ45) port
- 6 x Audio jacks
Internal I/O Ports
- 1 x USB 3.0 connector supports additional 2 USB 3.0 ports
- 2 x USB 2.0 connectors support additional 4 USB 2.0 ports (1 connector shares with ROG_EXT header)
- 1 x ROG extension (ROG_EXT) header
- 8 x SATA 6Gb/s connectors
- 1 x CPU fan connectors for smart DC/PWM mode control
- 1 x CPU optional fan connector
- 3 x Chassis fan connectors
- 1 x 24-pin EATX power connector
- 1 x 8-pin EATX 12V power connector
- 1 x Clear CMOS jumper
- 1 x Power-on button
- 1 x Reset button
- 1 x DirectKey button
- 1 x MemOK! Button
- 1 x DRCT (DirectKey) header
- 1 x S/PDIF out header
- 1 x Front panel audio connector (AAFP)
- 1 x System panel connector
- 1 x TPM connector
Accessory
- User's manual
- Support DVD
- I/O Shield
- 3 x 2-in-1 SATA 6Gb/s cables
- 1 x SLI bridge
- 1 x 2-in-1 Q-Connector Kit
- 1 x 12 in 1 ROG Cable Label
- 1 x ROG Door Hanger
BIOS
- 64Mb UEFI AMI BIOS, PnP, DMI2.0, WfM2.0, SM BIOS 2.5, ACPI2.0a Multi-Language BIOS
Manageability
- WfM 2.0, DMI 2.0, WOL by PME, PXE
Software Drivers
- ROG GameFirst II
- ROG RAMDisk
- ROG CPU-Z
- ROG Mem TweakIt
- Kaspersky® Anti-Virus
- DAEMON Tools Pro Standard
- ASUS WebStorage
- ASUS Utilities
Form Factor
- ATX Form Factor, 12” x 9.6” (30.5cm x 24.4cm)
Was £176.99 Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard @ £184.99 inc VAT
TUF, stands for The Ultimate Force.
The TUF series delivers a “tough” image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 4th generation Intel® Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset provides maximum 6 USB 3.0 ports and maximum 6 SATA 6Gb/s ports for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset also supports iGPU function, letting users enjoy the latest Intel integrated graphic performance.
CPU
- LGA1150 socket for 4th Generation Intel® Core™ i7/ i5/ i3, Pentium®/Celeron® Processors
- Supports 22nm CPU
- Supports Intel® Turbo Boost Technology 2.0*
- ** Refer to www.asus.com for CPU support list
Chipset
Memory
- 4 x DIMM, Max. 32GB, DDR3 1866/1600/1333 MHz, non-ECC, un-buffered Memory
- Supports Intel® Extreme Memory Profile (XMP)
- * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL (Qualified Vendors List) for details.
- ** Refer to www.asus.com or this user manual for the Memory QVL(Qualified Vendors List).
Expansion Slots
- 2 x PCI Express 3.0/2.0 x16 slots (Single at x16, Dual at x8/x8)
- 1 x PCI Express 2.0 x16 slot* [black] (Max. at x4 mode, compatible with PCIe x1 and x4 devices)
- 3 x PCI Express 2.0 x1 slots**
- * The PCIe 2.0 x16 slot shares bandwidth with PCIe 2.0 x1_1 slot, PCIe 2.0 x1_2 slot , PCIe 2.0 x1_3 slot and eSATA 6Gb/s ports. The PCIe 2.0 x16 slot default setting is in x1 mode.
- ** The PCIe 2.0 x1_1 slot shares bandwidth with eSATA 6Gb/s ports. The PCIe 2.0 x1_1 slot default setting is disabled.
VGA
- Integrated Graphics Processor- Intel® HD Graphics support
- Multi-VGA output support: DisplayPort/HDMI port
- Supports DisplayPort 1.2 with max. resolution 3840 x 2160@60Hz
- Supports HDMI with max. resolution 4096x2304@24Hz / 2560x1600@60Hz
- Supports Intel® InTru™ 3D/Quick Sync Video/Clear Video HD Technology/Insider™
- Maximum shared memory of 1024MB
Multi-GPU support
- Supports NVIDIA® Quad-GPU SLI™ Technology
- Supports AMD® Quad-GPU CrossFireX™ Technology
Storage
- 6 x SATA 6Gb/s ports (brown) with RAID 0, 1, 5, 10 support
- Supports Intel® Smart Response Technology, Intel® Rapid Start Technology, Intel® Smart Connect Technology*
- 2 x ASMedia® 1061 SATA controllers**:
- 2 x SATA 6Gb/s ports (beige)
- 2 x eSATA 6Gb/s ports (red)
- * These functions will work depending on the CPU installed.
- ** These SATA ports are for data hard drivers only. ATAPI devices are not supported.
LAN
- Intel® I217V Gigabit LAN controller
Audio
- Realtek® ALC1150 8-Channel High Definition Audio CODEC
- High quality 112dB SNR stereo playback output (Line-out@back) & 104dB SNR recording input (Line-in) support
- Absolute Pitch 192khz/24bit True BD Lossless Sound
- BD Audio Layer Content Protection
- Supports Jack-Detection, Multi-streaming, and Front Panel Jack-Retasking
- Optical S/PDIF out port at back I/O
USB
- Intel® Z87 Express Chipset - supports ASUS USB 3.0 Boost
- 2 x USB 3.0/2.0 ports at mid-board for front panel support
- 4 x USB 3.0/2.0 ports at back panel (blue)
- 8 x USB 2.0/1.1 ports (4 ports at mid-board, 4 ports at back panel)
Exclusive TUF Features
- "Ultimate COOL!" Thermal Solution
- TUF Thermal Armor with Flow Valve
- TUF Thermal Radar 2 with Thermistors
- "We Got Your Back!" Shape Force
- TUF Fortifier
- "TUF ENGINE!" Power Design
- 8+2 Digital Phase Power Design
- TUF Components (Choke, Ti-Cap & MOSFET; certified by military-standard)
- ASUS DIGI+ Power Control Utility
- "Safe & Stable!" Guardian Angel
- Dust Defender with connector covers and back I/O dust filter
- ESD Guards
- MemOK!
Other Special Features
- USB 3.0 Boost featuring speedy USB 3.0 transmission
- USB BIOS Flashback with USB BIOS Flashback Wizard for EZ BIOS download scheduling
- USB Charger+ featuring quick-charging function for all smart devices
- ASUS Remote GO! with Cloud GO!, DLNA Media Hub, Remote Desktop, File Transfer
- ASUS UEFI BIOS EZ Mode featuring friendly graphics user interface
- AI Suite 3
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- EZ Update
- Disk Unlocker
- ASUS EZ Flash 2
- Multi-language BIOS
Back Panel I/O Ports
- 1 x DisplayPort
- 1 x HDMI port
- 1 x Optical S/PDIF Output
- 1 x USB BIOS Flashback Button
- 4 x USB 3.0/2.0 ports (blue, 1 supports USB BIOS Flashback)
- 4 x USB 2.0/1.1 ports
- 8-channel Audio I/O ports
Internal I/O Connectors
- 1 x USB 3.0/2.0 connector supports additional 2 USB 3.0/2.0 ports (19-pin; moss green)
- 2 x USB 2.0/1.1 connectors support additional 4 USB 2.0/1.1 ports
- 8 x SATA 6Gb/s connectors (6 x brown; 2 x beige)
- 1 x CPU Fan connector (4-pin Black) for both 4-pin(PWM mode) and 3-pin(DC mode) CPU coolers control
- 1 x CPU OPT Fan connector (4-pin Black)
- 4 x Chassis Fan connectors (4-pin Black)
- 2 x Assistant Fan connectors (3-pin White)
- Front panel audio connector (AAFP)
- 24-pin EATX Power connector
- 8-pin EATX 12V Power connector
- System Panel (Q-Connector)
- 1 x MemOK! Button
- 3 x T_Sensor (Thermal Sensor) headers
- 1 x S/PDIF Out header
- 1 x TPM header
BIOS
- "64 Mb Flash ROM, UEFI AMI BIOS, PnP, DMI2.7, WfM2.0, SM BIOS 2.7, ACPI 5.0, Multi-language BIOS,
ASUS EZ Flash 2, ASUS CrashFree BIOS 3, My Favorites, Quick Note, Last Modified log, F12 PrintScreen, F3 Shortcut functions, and ASUS DRAM SPD (Serial Presence Detect) memory information"
Manageability
- WfM 2.0, DMI 2.7, WOL by PME, PXE
Accessories
- 4 x Serial ATA 6Gb/s cables
- 1 x ASUS SLI bridge connector 7cm
- 1 x ASUS Q-Shield
- 1 x 2 in 1 Q-connector
- 2 x Accessory Fans(35mm)
- 1 x TUF Accessory Package
- 3 x Thermistor cables
- 1 x back I/O dust frame
- 1 x back I/O dust grid
- 1 x connector dust cover collection (On board USB 3.0, DVI, HDMI, DP, LAN)
- 10 x USB 2.0 connector dust covers (On board x 2, back x 8)
- 9 x SATA connector dust covers (On baord x 7, eSATA x 2)
- 6 x Audio connector dust covers
- 3 x PCIe x16 slot dust covers
- 2 x DRAM slot dust covers
- 3 x PCIe x1 slot dust covers
- 2 x Short fan screws
- 4 x Long fan screws
- 1 x 40mm I/O Cover fan lid
- 1 x Adhesive Sponge for 35mm Fan
- 1 x TUF Inside sticker
- 1 x TUF Certification card
- 1 x TUF 5 Year Warranty manual (by region)
- TUF Accessory Installation Guide
- User's manual
Support DVD
- Drivers
- Anti-virus software (OEM version)
- ASUS/TUF CPU-Z
- ASUS Utilities
Form Factor
- ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
Was £199.99 Inc. VAT
Only £184.99 inc VAT.
ORDER NOW
Asus Z87 GRYPHON Intel Z87 (Socket 1150) DDR3 Micro ATX Motherboard @ £119.99 inc VAT
The TUF series delivers a “tough” image. With the unique design & high quality components (military-standard), TUF series is born for pursuing the preeminent stability, all-round compatibility, and extreme durability.
The Intel® Z87 Express Chipset is a single-chipset design to support socket 1150 Intel® 4th generation Core™ i7/i5/i3/Pentium®/Celeron® processors. It provides improved performance by utilizing serial point-to-point links, allowing increased bandwidth and stability. Additionally, Z87 chipset features both the USB 3.0 & SATA 6Gb/s technology for faster data retrieval speed. Moreover, Intel® Z87 Express Chipset can also enable iGPU function, letting users enjoy the latest Intel® integrated graphic performance.
CPU
- Supports 22nm CPU
- ** Refer to www.asus.com for CPU support list.
Chipset
Memory
- * Hyper DIMM support is subject to the physical characteristics of individual CPUs. Please refer to Memory QVL(Qualified Vendors List) for details.
Expansion Slots
- 1 x PCI Express 2.0 x16 slot [black] (Max. at x4 mode, compatible with PCIe x1 and x4 devices)
- 1 x PCI Express 2.0 x1 slot
VGA
- Multi-VGA output support: HDMI/DVI port
- Supports HDMI with max. resolution 4096x2160@24Hz / 2560x1600@60Hz
- Supports DVI with Max. resolution 1920x1200@60 Hz
- Supports up to 2 displays simultaneously
Multi-GPU support
Storage
- * Supports on Intel® Core™ processor family with Windows 7 operating systems.
LAN
Audio
- Realtek® ALC892 8-Channel High Definition Audio CODEC
USB
- Intel® Z87 Express Chipset- supports ASUS USB 3.0 Boost UASP Mode.*
- *The USB 3.0 ports only support Windows® 7 or later versions. UASP standard only supports Windows® 8
- ESD Guards
- MemOK!
- AI Suite 3
- ASUS Q-Connector
- ASUS Q-Shield
- ASUS Q-Slot
- ASUS Q-DIMM
- ASUS O.C. Profile
- EZ Update
- Disk Unlocker
- ASUS EZ Flash 2
- 1 x DVI-D port
- 1 x HDMI port
- 6 x SATA 6Gb/s connectors (brown)
- 1 x Assistant Fan connector (3-pin White)
- Front panel audio connector(AAFP)
- 1 x MemOK! button
- 1 x DRCT(DirectKey) header
- 3 x T_Sensor(Thermal Sensor) headers
- 1 x Thunderbolt header
- 1 x TPM header
BIOS
Manageability
Accessories
- 1 x ASUS Q-Shield
- User's manual
Support DVD
- Drivers
- Network iControl
- ASUS Utilities
Form Factor
- uATX Form Factor, 9.6”x 9.6” (24.4cm x 24.4cm)
Was £129.95 Inc. VAT
Only £119.99 inc VAT.
ORDER NOW
Asus Crosshair V Formula Z AMD 990FX (Socket AM3+) DDR3 Motherboard @ £176.99 inc VAT
ASUS Republic of Gamers, (ROG), offers only the best hardware engineering, the fastest performance and the most innovating ideas.
The Crosshair V Formula Z with AMD 990FX chipset-based is not only the first ROG motherboard with AM3+ CPU support, but it is also the first ever AMD motherboard to support both 3-Way NVDIA® SLI™ and AMD CrossFireX™, as well as offering UEFI BIOS. The usual selection of advanced ROG overclocking tools are on hand too, whilst on-board SupremeFX X-Fi 2 delivers the most intense and immersive gaming audio experience. Better still, high-performance Intel® Ethernet with GameFirst technology creates a LAN connection that is fast enough to keep up with the pace of modern multiplayer gaming over an internet connection that is also used being used for other online tasks.
ASUS Unique Selling Points:
Extreme Engine Digi+: A Powerful combination of analog and digital Phase Power design elements.
GameFirst: Optimized network bandwidth designed to succeed.
CPU Level Up: A simple click for an instant performance upgrade!
ROG Connect: Plug and Overclock - Tweak it the hardcore way!
- RC Poster
- RC Remote
- RC Diagram
GPU TweakIT: Safely Overclock your GPU performance.
GPU.DIMM Post: Easily check the status of your graphics cards and memory in the BIOS!
Bios Print: Easily print your bios settings.
Extreme Tweaker:One stop performance tuning shop.
ASUS TPU with Auto Tuning and TurboV: Providing simple steps to easy overclocking.
O.C. Profile: Allows you to store multiple Bios images.
COP EX (Component Overheat Protection - EX): Maximum OC with confidence via burn proof protection to chipsets and GPU!
Voltiminder LED: Friendly reminder for to extreme Voltage Settings.
Core Unlocker: Safely unlock latent CPU cores for Free.
Fan Xpert: Smart thermal control via fan speed detection.
ASUS Q-Connector: Easily access your PCI-E connectors.
ASUS Q-Shield: Protect yourself from EMI.
ASUS Q-LED (CPU, DRAM, VGA, Boot Device LEDs)
EZ Flash 2: Easily update your systems bios firmware.
ASUS MyLogo 3: Customize your boot screen.
Key specification:
- Form Factor: ATX Form Factor, 12”x 9.6” (30.5cm x 24.4cm)
- Socket: AMD Socket AM3+ for FX™ / Phenom™II / Athlon™II / Sempron™ 100 Series Processors
- Chipset: AMD 990FX / SB950 Chipset
- Graphics interface: 3 x PCIe 2.0 x16 (dual x16; x16 x8 x8)
- Expansion Slots: 1 x PCIe 2.0 x16 (x4 speed) 1 x PCIe 2.0 x1, 1 x PCI 2.2
- Multi GPU: Supports 3-Way NVIDIA® SLI™ / AMD CrossFireX™ Technology
- Memory: 4 x DIMM, max. 32GB, DDR3 2133(O.C.)/2000(O.C.)/1800(O.C.)/1600/1333/1066 MHz, ECC and non-ECC, un-buffered memory, Dual channel memory architecture
- Audio: SupremeFX X-Fi 2 built-in 8-Channel High Definition Audio CODEC
- LAN: Gigabit Intel® Ethernet LAN
- Storage: 6 x SATA 6Gb/s ports with RAID 0, 1, 5, 10, red, - 1 x SATA 6Gb/s port, red, - 1 x eSATA 6Gb/s port, red
- USB: 6 x USB 3.0/2.0 ports (4 at back I/O, blue; 2 at mid-board), 12 x USB 2.0/1.1 ports (7 ports at back I/O, black, 4 ports at mid-board, 1 port at back I/O can be switched to ROG Connect, white)
- Manageability: WOL by PME, WOR by PME, PXE
Back Panel I/O Ports:
1 x PS/2 Keyboard/Mouse Combo port
1 x External SATA port
1 x LAN (RJ45) port
8 x USB 2.0/1.1 ports (1 port can be switched to ROG Connect)
1 x S/PDIF Out (Optical)
8-channel Audio I/O
1 x Clr CMOS switch
Internal I/O Connectors:
7 x SATA 6Gb/s connectors (Red)
2 x CPU Fan connector(s)
3 x Chassis Fan connector(s)
3 x Optional Fan connector(s)
8 x ProbeIt measurement points
3 x Thermal sensor connectors
1 x SPDIF out connector
1 x 8-pin ATX 12V power connector
1 x 4-pin ATX 12V power connector
1 x EZ Plug connector (4-pin Molex Power connector)
1 x En/Dis-able Clr CMOS header
1 x CPU Level Up button
1 x ROG Connect switch
1 x START (Power on) button
1 x RESET button
1 x Go Button
1 x Audio front panel (AAFP) header
In The Box:
1 x ROG Connect Cable
1 x 2-in-1 ASUS Q-Connector Kit
3 x 2-in-1 SATA 6.0Gb/s Cables
1 x 3-Way SLI Bridge
1 x SLI Cable
1 x Crossfire Cable
1 x Cable Ties Pack
1 x ROG Theme Label
1 x 12-in-1 ROG SATA Cable Label
1 x User's Manual
1 x I/O Shield
Drivers
Sound Blaster® X-Fi 2 Utility
ROG CPU-Z
ASUS Utilities
Was £194.99 Inc. VAT
Only £176.99 inc VAT.
ORDER NOW
HI there
Remember guys, the 670/680 series crazy deals are for this weekend ONLY on Pre-Order basis. The stock lands Monday, but the price goes up at 9am, so be sure to pre-order over the weekend to take advantage of this insane pricing. :D :D :D
No 7990 price drop? Poor show
We are working on something more special on 7990 with AMD. The current prices were seeing, we think are not good enough, we hope to post a 7990 deal next week, we just want something awesome to offer our customers and hopefully that will happen late next week. :)
<3
Unbelievable pricing:eek:
How much faster are the 670s compared to my unlocked 6950??
I'd love two in SLI but was kinda holding out for the new AMD cards but at that price it's extremely tempting..
I hate this site!!! :mad::mad:
Evil, Evil man Gibbo!!! :p
The temptation is hard to resist !! :eek:
Hmm! should I risk it or take a knife in the back from the missus!!! :confused:
Bin bags ready !! off for a chat.... :p
