- 28 Feb 2013
- Leeds
Hey guys.
current Pc spec.
FX6300 @ 4.1
gigabyte 78lmt-usb3 motherboard
HD5770 1G Radeon GPU
Corsair xms3 1333 DDR3 ram
2 x 500 GB WD green sata 2 HDD's
Now.. i have it over clocked to 4.1 without using the CPU boost option.
, i had to p the multi to 20.5. and upt the voltage to 1.337 from 1.335 (not a massive oost, ut it made it stable at 4.1.
now, if i up the multi to 21, windows loads fine, ut as soon as i open prim95, it starts, but then 2 and 4 stop working.. then the PC just freezes.
i tried upping the voltage, but just does the same thing..
also, when at 4.2 i couldnt even open coretemp, it just crashed the system and restarts.
i am thinking to myself that my motherboard cant cope with it. but i could be wrong, and this is why im here asking for some info
if you need anymore info, just let me know, cheers guys
EDIT: can i just add, my load temps at only hitting 37c with prime95 with the CPU @ 4.1. and 39-41 coretemp.
EDIT 2: Motherboard specs Here
lol EDIT 3:
, i keep forgetting to add things
, i have disabled C&C in bios aswell. but i don't know if there is anything else to disable, i don't want to trn things on and off because im scared of braking it.. had bad exp with bios in the past
current Pc spec.
FX6300 @ 4.1
lol EDIT 3:
