- 26 May 2008
Hi all,
I have rebuilt a PC out of some old parts, but feel I need to upgrade some bits n bobs. Bang for buck I am thinking, though it may go onto a better build in future if it gets a lot of use.
The current spec.
Asus P5QL-VM EPU motherboard.
Intel Core 2 Duo E6400 2.13Ghz CPU. (Stock cooler)
Corsair PC2-6400C5 2x2GB memory.
Samsung HD502HJ 500GB F3 HDD.
Windows 7 64bit.
Hiper TypeR 480w non modular PSU. (Molex everywhere and only two sata power
Silverstone TJ08B-E MicroATX case.
This is going to be used by one of my sons, Minecraft mainly, then maybe put together as an experimental server using Amahi and some old HDD's when they are freed up.
I think I need a better PSU, to be honest, as quiet a PSU as possible, and preferably under 160mm in depth? Modular is a bonus.
There is a possibility it may receive a GPU, but I doubt it will ever be more than an HD-5750 or GTX-660, both of which have a single 6 pin. But it may end up with up to 6 Sata II devices to power up.
I would like the quietest 120mm case fan for the case rear, I have an Apache that sounds like a full blown hairdryer as the mobo has no chassis fan control.
And a PCIe 2.0 x1 or PCI wireless card? Something that offers better connection than the TP-Link and D-Link USB adapters I currently have.
Maybe a silent 775 CPU cooler, as I doubt it will ever have a CPU exceeding 65w.
So any recommendations on,
Power supply.
Very quiet 120mm fan.
PCIe 2.0 x1 or PCI wireless card.
Very quiet 775 CPU cooler.
The current spec.
Windows 7 64bit.
Power supply.
