Corrupt Evga Gtx 780 bios?
8 Mar 2010
TBagTowers
I had 2 x 780 installed and left machine transcoding video. Came home to machine powered down and this when I start up
Its covered with warranty whatnot its just the inconvenience of shipping and waiting for the replacement so I had a closer look at the card.
Its the same Evga 780 as my second card but they have 2 different bios revisions the goosed one is bios version 80.10.3A.00.82 but cannot get it to boot to windows and am assuming it would void the warranty if I flashed it with the bios from the other card.
So my question is does anyone have the 80.10.3A.00.82 bios version for an evga gtx 780 I might be able to save myself £30 mailing cost and a few weeks without the card which would be good because I have all my gear piled up ready to go water and cannot do a thing until this is sorted.
Any advice would be welcome :(
Does the EVGA rep still visit here. Could ask him to email said bios
Have a read of this, it looks like you may need to update the bios.
http://www.evga.com/forums/tm.aspx?m=1990939
Evga allow you to flash the bios as long as if you have to return it you put the original one back on.
Thanks for that will have a read and take a look for the evga rep
Why'd you think it's BIOS related?
Just looks like a card's snuffed it.
In truth I have no idea I just assumed what with the corrupted signal, have checked cable and tested everything I could think of
Hi,
if it is about technically or support questions best is to get in contact with us at [email protected] or contact us at the EVGA Sticky here in the forums.
A Bios can get corrupted or do not match, with a SLI System it is worth to give it a try but it is most likely that the card is faulty.
