I recently decided I'd try to overclock my 955, which is where my issue arose. I downloaded cpu-z and found my chip to be the c3 variant, great I thought. Until I had a look at the temps it runs at..I idle in windows at around the 45 mark and was breaching 60 degrees whilst gaming. Which is very close to the 62 recommended max. It's not been overly hot the past few days which would indicate the chip has been running over 62 at some point in its life without any problems (so I would hope no damage has been done). It does however leave no room for overclocking. If I'm right I should be looking at a possible 4ghz?
This is on auto volts (1.344) and clock (3.2), with an Arctic Cooling Freezer 7 Pro Rev 2.
My question is, would undervolting make much of a difference or am I better off buying a brand new cooler?
If reseating the cooler is a suggestion I'm probably better off spending some money on a brand new one instead of wasting time. Any suggestions? Needs to fit in an Antec 300 case, which may limit my options, but budget isn't too much of an issue.
Thanks!
Thanks!
