Build check 1k-1.4
YOUR BASKET
1 x MSI Geforce GTX 770 Gaming Edition 4096MB GDDR5 PCI-Express Graphics Card £359.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Gigabyte Z87X-OC Intel Z87 (Socket 1150) DDR3 ATX Motherboard £167.99
1 x Corsair Professional Series AX 760W '80 Plus Platinum' Modular Power Supply (CP-9020045-UK) £149.99
1 x Samsung 250GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE250BW) £148.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £41.99
1 x BitFenix Alchemy Premium Modding LED Strip - Aqua Red 50cm £29.99
2 x Prolimatech Red Vortex Red Wings Red LED 120mm Fan £10.99 (£21.98)
Total : £1,345.44 (includes shipping : £10.50).
Better motherboard, better RAM and you dont need 16gb for gaming, 8gb is barely used on the most demanding games. They are CPU intensive if anything.
You could also invest in some Braided cable to match the build:
YOUR BASKET
1 x BitFenix Alchemy 24pin ATX extension 30cm - Orange £8.99
1 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved orange/black £5.99
1 x BitFenix Alchemy 8pin EPS extension 45cm - Orange £5.99
3 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Orange £5.99 (£17.97)
2 x BitFenix Alchemy Molex to SATA Adapter 45 cm - sleeved orange/black £5.98 (£11.96)
Total : £55.87 (includes shipping : £4.16).
whats the reasoning behind gpu? out of curiousity
since I was hopinh for 2.5k res gaming
The 4gb of vRam will really help to that resolution especially if you are gaming over multiple monitors. The 780 is very expensive for what it is and personally wouldn't recommend it. I would certainly consider the 770 as it's more than capable and with 4gb, you can't go wrong.
I have much love for Snips build, it looks great and as said the 4GB will help with higher res gaming. :)
I also like idles spec but going SLI in that case wouldn't be ideal.. The cards will be back to back (well front) and heat will be an sisue, where in snips build they'll be an air gap.
I like the braided cables too. :)
Thats why mine is a halfway house ;) SLI GTX670's and a much bigger case, it also is completely red and black with all the braided cables ...... barring the fact that I have just noticed that I needed to include another 6 Pin & 8 Pin PCI-e cables ........ (hides in corner and hangs head in shame :()
I will just be using one monitor what kind of fps will you get
