These past couple of weeks the car is struggling to start, I have to turn it over 3 times and hold the revs to 15000 to keep it going before I start my journey.
I did have a coolant leak a month back the water inlet valve snapped on the inlet manifold, after a week of fixing the water leak. I've check the throttle body no leakage no loose parts etc. Fuel filter strap snapped but that is cable tied up, spark plugs replaced, coilpack seems in good condition.
I haven't checked the fuel pump is working as normal yet and I am hoping it isn't as it costs up to £100 for a replacement. I am wondering if the idle valve/sensor is faulty.
Any other stuff I could check?
