PSU is out of stock and go with this XFX PSU:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-005-XF&groupid=701&catid=123&subcat=1497
And do you want the Bitfenix with a window?
Looks good, though this RAM may be better for that price range?
http://www.overclockers.co.uk/showproduct.php?prodid=MY-003-AR&groupid=701&catid=8&subcat=1387
Just seen your revised spec, that PSU seems total overkill to me to be honest mate. Cooler and Case maybe are too, but if you want a strong overclock it's understandable.
Assuming you want (or may want) to go SLI later on yeah?
Were it in stock I'd have also said this:
http://www.overclockers.co.uk/showproduct.php?prodid=CA-012-XF
Or the one RJC recommended if your not fussed about modular:
The latter being great value![]()
What exactly is wrong with the Corsair AX860i, out of interest?
Nothing at all wrong with it, it's a great PSU, but it's £180.
To my mind that's a big chunk of the budget for no real gain over a cheaper model, but it's your money mate![]()
I just like the fact that'll it be quiet under low-loads. For editing, silence is a must.
