You've not added Windows?
Hows this look?
YOUR BASKET
1 x Intel Core i5-3470 3.20GHz (Ivybridge) Socket LGA1155 Processor (77W) - Retail £155.99
1 x PNY Nvidia Quadro 410 Graphics Card - 512MB - GDDR3 SDRAM £124.99
1 x Kingston HyperX Genesis Blue 16GB (2x8GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (KHX16C9K2/16X) £101.99
1 x Gigabyte H77-D3H Intel H77 (Socket 1155) DDR3 Motherboard £80.99
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £49.99
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £39.95
1 x Xigmatek Asgard Pro Gaming Case - Black £32.99
Total : £600.98 (includes shipping : £11.75).
Haha these things soon creep up in price!!!
Why do you suggest the FX route over i5? I suppose the IGP will get the pc up and running until a decent GPU pops up used...
It's not actually a bad choice: http://www.xbitlabs.com/articles/cpu/display/amd-fx-8350_5.html#sect0
Though personally i'd go for your haswell build without the card and grab a secondhand card...
It will perform better in some tasks, especially if overclocked (your haswell build is a non-k chip).
It's also a lot closer to your original budget.
Oh god now I'm loosing it... Non k chip? Single/multi threaded-what's 3d rendering?
I would be shocked if an i3 outperformed a 8320 in rendering with modern programs.
If you want a mild OC, you'll need a k chip and a better motherboard for the Haswell spec and a £25 after market air cooler ideally. aka more cost.
120GB/128GB should be fine with a external HDD plugged in for file storage.
I'm not particularly pro-AMD, I just think it's a better choice if you want to keep close to your original budget.
