I May Have Slightly Overlooked Something
17 Jun 2012
South Wales
Hi all
I bought a Gigabyte 787X-OC to go with my new I5. However I just noticed that the motherboard requires a 4 pin and a 8 Pin ATX 12v but my PSU, an generation old Corsair HX 650 Bronze only has one 8 pin connector. Does anyone have any suggestions other than buy a new PSU?
Akasa 4 pin to 8 pin ATX PSUhttp://www.overclockers.co.uk/showproduct.php?prodid=CB-063-AK&groupid=1929&catid=153
Why would a mobo have two power connectors if it'll work OK with only one of them connected?
Posted from Overclockers.co.uk App for Android
Usually the 2nd is only required for extreme CPUs and/or when your really pushing overclocking i.e. in the LGA775 days you only needed 2x4 pin in most cases if you were using a power hungry quad core instead of a dual core.
