New build
6 Oct 2004
Widnes, Cheshire
I have put this together and would like your opinion, anything drastically wrong as the last time i did this was 3 years ago.
YOUR BASKET
1 x KFA2 GeForce GTX 780 LTD OC 3072MB GDDR5 PCI-Express Graphics Card **ALL WHITE HOF** £575.99
1 x Iiyama Prolite G2773HS 120Hz 27" Widescreen LED 1MS Monitor - Black £329.99
1 x Samsung 500GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE500BW) £289.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Asus Z87 MAXIMUS VI FORMULA Intel Z87 (Socket 1150) DDR3 ATX Motherboard £259.99
1 x Seasonic 1000w '80 Plus Platinum' Modular Power Supply £189.95
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £111.98
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
2 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (AVD3U24001004G-2CI) - Blue Light £79.99 (£159.98)
1 x Western Digital Caviar Black 1TB SATA 6Gb/s 64MB Cache - OEM (WD1002FAEX) HDD £76.99
3 x Corsair AF120 Quiet Edition Low Noise High Airflow - Single Pack (CO-9050001-WW) £13.99 (£41.97)
1 x Coollaboratory Liquid Ultra Thermal Paste £8.99
1 x BitFenix Alchemy 24-Pin ATX Extension 30cm - sleeved black/red/black £7.49
1 x BitFenix 6-Pin PCIe Extension 45cm - sleeved black/red/black £5.99
1 x BitFenix 8-Pin PCIe Extension 45cm - sleeved black/red/black £5.95
1 x BitFenix Alchemy 8-Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
Total : £2,557.14 (includes shipping : £19.10).
Many thanks
Brian
A few pointers,
• WD Blacks are expensive, you can get Seagate Barracuda 2TB for the same money.
• The RAM light, will it match?
• The thermal paste is a pain to use, the H100i does come with pre-applied silver based compound.
A few pointers,
Your right about the ram led's
will look at the hard drive
will the pre-applied paste be ok?
can you advise on the memory
Thanks
My finger is hovering over the buy button.......but a little voice in my head is saying wait for the IB-E is there any benefit waiting in your opinion?
Brian
There's no real benefit unless you do editing/encoding etc, that's with the hex core chips, the quad core (4820K ?) will be very very similar in speed to the 4770K chip.
If you're wary about the CPU/board, then maybe go for a cheaper board. There are loads of good options in the £120-£200 range.
Thanks, think i'll buy as it stands :)
Brian
