Build around these components
total cost is 1572. what do you think of this?
Not a-lot. :p
I would get an i7 and a 770 with your budget personally, and then overclock them both. But the i5 and 780 combination works fine too.
I would get a 256GB SSD rather than a 120GB as you will find the 120 filling up quite fast.
I wouldnt get an MSI motherboard, I would get a Gigabyte Z87X-D3H.
I wouldnt touch a Phantom case with a barge pole because it may be £110 but it looks like it should cost half that. I would get something with a far better metal construction if you want to spend that much on a case.
The PSU is alright, but I wouldn't get that model, I would plump for a 750W 80+ Silver XFX XXX like mine, A Corsair TX750 or a Seasonic.
You would also benefit hugely from getting aftermarket cooling as you wont be overclocking that CPU without it, and it will run quite hot even at stock clocks.
Not a-lot. :p
thanks for reply. Why would you go with the gigabyte board for? What case would you recomend instaed
You nailed it Doomedspeed. :p
It is indeed a stonking rig. :)
You could get an 850W PSU I suppose, just so that it leaves the possibility of adding a second GTX770 in the future as well as allowing overclocking headroom for both 770's and the i7.
A 750 would be fine for the i7 & 770 though. :)
The 750w PSU will be for SLI and overclocking the i7.
:D
:p
I sometimes forget how little power these cards use... :p
My GTX480 must have had an effect on my mind. :D
