£500 gaming RIG
14 Aug 2012
Merthyr, Wales, UK
hey guys i am looking to get a spec for a gaming PC with a new haswell i5 4670K processor and a good mobo.
Will not need the monitor, OS, case, and will be getting a GFX card at a later date so this will not be included in the build.
I will also be looking into SLI in the future so will need a good compatible mobo and PSU.
What would you suggest
Thanks
Daniel Bell
Here you go
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x Gigabyte Z87X-D3H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £131.99
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) £65.99
Total : £510.76 (includes shipping : £9.00).
edit:
I misread the PSU being needed, thought it was already there. That rules out the H100i.
Yeah may be better to play it safe, think it's probably ok, so may be worth the OP checking with customer services if he decides to go with it.
Your choice certainly does look better :)
