- 25 Jul 2009
- England
Hello.
As im looking at upgrading my GPU from the GTX460 to a 660ti or something similar I was told to overclock my cpu from 3.4ghz to 4.0ghz as at 3.4ghz it will bottleneck any good graphics card.
Ive just set it to [x20] which is 4.0Ghz. However I couldn't find where to up the voltage to "1.5250" so I restarted the system anyway and it blue screened. It seems to be ok now its back to 3.4Ghz for the time being.
I noticed in the BIOS there is some kind of overclock boost setup. Is it worth going through this to overclock my CPU? Maybe use programs instead of doing it through the BIOS so I can edit the voltage?
Thanks
EDIT:
Found out how to change the voltage. It is the CPU voltage I need to up isn't it? I did see a youtube video and he upped it to 1.5250 but it seems I can't get it bang on that number. Any number around this shows up in red.
Thanks
EDIT:
