Spec me up £3k rig.
Sgarrista
System Admin
9 Aug 2013
Bromsgrove
So, my samsung evo drive turned up this morning to bide things over until the new rig was ready, unfortunately my current mobo does not support AHCI, so I am unable to use the drive to its full potential. :(
In light of such a disaster... i'm forced to bring my new build forward :D
Usage wise, it will be used for hardcore gaming, including MMO multiboxing. Web design and graphics work, as well as high quality video rendering and finishing (after effects etc).
I already have the 1 samsung evo for the OS, commonly uses files and programs. Will buy another one to run games from, and then also use my current 2tb storage drives, or potentially buy new ones to transfer and sort data out.
Heres what i've currently got:
Now the difficulties.
Havent properly specced the PSU yet, so thats a placeholder.
Can't decide on a case, I would like a caselabs case, but at £600-£700 this seems unrealistic, so may need to track one down second hand, or find an alternative... which isn't going to be easy.
Cooling... with such a nice setup, maybe its worth watercooling. I'll use the CPU step up option Asus provide, but otherwise won't be overclocking (probably).
My concern with watercooling is previously I had a watercooled setup which had a resonance... hard to explain, but it drove me crazy, imagine something like this:
is that something thats still around or are the pumps better nowdays?
fav color?
Black :D
Though if looking at the whole build, basically keep things matching, eg the asus board is black and red, so would match everything else to that, havent decided on the lighting though, not sure on red or the classic blue.
How's this?
YOUR BASKET
1 x Samsung 1TB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE1T0BW) £509.99
1 x MSI HD 7990 6144MB GDDR5 PCI-Express Graphics Card with FREE GAMES £499.99
1 x Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
1 x Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard £169.99
1 x Patriot Venom Red 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV316G240C0KRD) £161.99
1 x Patriot Viper "Black Mamba" Generation 3 16GB (2x8GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (PV316G240C0K) £161.99
1 x Seasonic X-Series 850w '80 Plus Gold' Modular Power Supply £159.95
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £111.98
1 x Corsair Hydro H100i High Performance Liquid CPU Cooler £103.99
1 x LG BH16NS40 16x SATA Internal BDRW - OEM £74.99
1 x BitFenix Recon Internet-Connected Fan Controller (Black) £29.99
1 x BitFenix Alchemy Premium Modding LED Strip - Aqua Red 50cm £29.99
1 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £25.99
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
5 x Aerocool Shark Devil Red Edition LED Fan - 140mm £7.99 (£39.95)
3 x BitFenix 6+2-Pin PCIe Extension 45cm - sleeved red/black £5.99 (£17.97)
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved red/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Red £4.49
Total : £2,414.18 (includes shipping : £12.50).
Ok, I have no idea what's going on in there :p
A D5 and a tube res should be pretty much silent if you decouple the pump (use a sponge type of thing or hang it off the res) . Mine are :)
Yea, its a P4 system, shows how long ago it was I watercooled :eek:
Not sure what res/pump tops are, but I believe he's using D5 pumps with Bitspower D5 mod kits (the chrome 'barrel' things).
If you want that kind of pimping, you'll have to spend a bit more :)
Then do a spec with the OC board, maybe UD4H and nerd porn RAM?
You mean like this?
YOUR BASKET
2 x Inno3D GeForce GTX 780 3072MB GDDR5 PCI-Express Graphics Card £549.95 (£1,099.90)
1 x Creative Sound Blaster ZxR PCI-Express High Performance Sound Card - Retail (70SB151000001) £199.99
1 x Gigabyte Z87X-UD4H Intel Z87 (Socket 1150) DDR3 ATX Motherboard £179.99
1 x Antec High Current Pro 850W Modular '80 Plus Gold' Power Supply £149.99
1 x Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £94.99
1 x Corsair Vengeance Pro Silver 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9) £89.99
1 x Corsair Vengeance Pro Red 8GB (2x4GB) DDR3 PC3-17100C9 2133MHz Dual Channel Memory Kit (CMY8GX3M2B2133C9R) £89.99
1 x BitFenix Alchemy Cable Bundle - Red £28.45
2 x Corsair AF120 Performance Series Low Noise High Airflow - Dual Pack £25.99 (£51.98)
1 x Corsair Fan, SP120 PWM Low Noise High Pressure Fan 4 pin, Dual Pack (CO-9050012-WW) £25.99
1 x Corsair AF140 Quiet Series Low Noise High Airflow - Single Pack (CO-9050009-WW) £14.99
1 x Corsair AF120 Performance Series Low Noise High Airflow - Single Pack £13.99
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x BitFenix Alchemy 8pin PCI-E extension 45cm - Red £6.98
1 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49
1 x OcUK Professional 2.5" to 3.5" SSD Adaptor Plate - Black £5.99
2 x BitFenix Alchemy SATA 6GB/s braided cable 30cm - Red £5.99 (£11.98)
1 x BitFenix Molex to 4x SATA Adapter 20 cm - sleeved black/red/black £5.99
2 x BitFenix Alchemy Molex to 3pin x3 Fan adaptor 7V 20cm - Red £4.99 (£9.98)
3 x BitFenix Alchemy 2pin I/O extension 30cm - Red £3.95 (£11.85)
Total : £2,517.96 (includes shipping : £13.75).
PS: loving the new siggy Snips :)
You mean like this?
YOUR BASKET
Sorry to hijack thread but how do you import the basket into the foruml like this?
