hi all, looking to buy Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card, think it will run Battlefield4 at ultra settings?
As the game isn't out - I doubt anyone knows
People in here
When ports of next generation games arrive and you have to turn down settings and run at lower resolutions just to get the games frame buffer to fit into your pidley 2Gb of VRAM I'll be quietly laughing at you from the side lines with my 3Gb of VRAM![]()
Given the lower price on the 7950 and the higher memory spec though I'd not recommend the 670, unless you adore PhysX.
For good BF4 performance you should get an AMD card. There's little to no chance you'll manage decent FPS at ultra on a single GPU, but you never know.
I think 2gb vram will be enough for 1080p bf4. However you might need to drop AA down to x2. I believe x4 will be right on the limit, not just the vram limit but also the gpu grunt required. I think 2gb should be fine though.
2gb at 1440p will not be enough i reckon with any form of aa though in bf4.
Those are my predictions and you can quote me on it.![]()
I predict for BF4 that one 7950 or 7970 will be enough for high settings at 1080p, but ultra will need two to get above 30fps. I also expect that 3GB VRAM will be needed for best performance at ultra. You can quote me on those too![]()
I hope BF4 comes with an in game bench tool.![]()
We'll see. That'll certainly be a shock if Ultra is unplayable without aa on a single gpu. I can't see it myself. I can see the game being a bit more demanding, but nothing drastic.
I live and pray for that. Just give us consistency, that's all we ask. That way there can be no differences. Right now it sometimes depends on which map the benchmarking site uses which is not very helpful.
I think 30fps on a clocked 7970 is a bit harsh![]()
It'll get to ultra on one GPU I expect - but only the 9970![]()
An overclocked 7970 will probably manage over 30fps yeah. I don't think there's any chance a single 7970 will do 60fps ultra though, not with a new engine and a new GPU coming out.
BF3 is Frostbite 2, BF4 is Frostbite 3 - I've no idea of the difference though (except Frostbite 3 has AMD optimisations).
Its not a new engine though, its the same engine. All they're (supposedly) doing is using more power of the engine. Interesting times ahead though. It looks stunning running on a 7990. I wonder what res they were using in that trailer video, 1080p most likely. I just hope i can max it out with my setup. x2 AA will do me, but x4 would be ideal. Just for willy waving rights over our 2gb brothers.
