- 13 Aug 2012
I am looking to get 50 fps plus with a 4770k/8gb/z87x-oc setup
What would be my best bet
Crossfire 7950 or sli 770
2x7950 definitely. Not sure id agree that 2x770 sli represents good bang for buck though in comparison. 2x670 maybe with the price reductions but that comes with no games and less vram/smaller bus size.
2x msi 7950 3gb, sell the 6 free games for £45 = £306 for 25% faster than a stock titan. That's the price of 1x770 btw.
The divide between the mid range - high end nvidia cards is quite big
There is no need to go SLI or crossfire. One high end card will be more than enough.
If you want to play on mid settings yes, if you want to play high/max then 2 cards is minimum!
A single 7970 does surprisingly well at 1440p with most games being able to run at max settings if you lower the AA a tad. My 780 ran everything at 1440p without any issues.
Saying you need two cards to enjoy 1440p is not really right. If AMD have sorted the stupid boost issues with crossfire a pair of 7950 cards as Matt said is a great choice or even a pair of the cheap 670 cards.
If you want 60FPS constantly, you'll need at least 2 cards.
But as I always say try a single card first and if you do not find it enough then buy another.
60fps it is an absolute number, it's not relative and no matter how much you try to sugarcoated, won't change a thing. Rock solid 60FPS remains butter smooth while anything under (3-4FPS) will be noticeable, more so if you play with an FPS cap.![]()
This is absolute nonsense.
