How old and how deaf are you?
aged 38 and I didn't do this test but I have to get my hearing checked yearly because of the food production environment I work in, from the tests I can hear all the way up to the 19000 range so I have the hearing of some one half my age.
18 and I couldn't hear 15,000Hz. Although I could hear some occasional clicking with any frequencies thereon.
To be fair I have had hearing problems since I was born along with various operations to try fix my hearing.
29, not tryed that yet but my last hearing test about 4 weeks ago told me I'm H1-H1
Good hearing apparently, especially considering what my ears have been through over the years, so i guess my poor hearing is down to selective listening not damaged hearing...
Age 25, I can hear up to 17000Hz. I'll try again when I get home as my work PC is crap and may be affecting it.
I'm 30 and could hear all of them. I found 16,000 hz the most difficult :confused:
Edit - tried it with headphones and got to 18,000Hz, after that, nothing :p
I could hear 12,000Hz, I couldn't hear either 15 or 16,000Hz, but then I could hear both 17 and 18,000Hz.
Confusing.
25, and pretty deaf, was born like it. Deaf in both ears, only wear the one hearing aid though, as I can luckily get away with it, sometimes.
I could do the test, but should I do it with or without my hearing aid? :p
49 and I could hear all of them when I set the video to 1080p.
Interesting; when I set it to 1080p I could hear all of them (in contrast to the default setting where I ran out of steam at 15KHz). However, past 15KHz the sounds started sounding lower in frequency which makes me suspect some distortion somewhere in the replay chain...
