Maths help (MacLaurin series)
9 Oct 2004
Paris
Hey all,
Resit tomorrow and i'm a bit stuck on Q1, part B.
http://img10.imageshack.us/img10/2053/b7q9.jpg
I understand you just differentiate the differential equation and sub in the initial conditions.. but all the examples i've had have had constant coefficients.. the '2x' throws me a bit... but as i've been given y(0) and y'(0) do i just negate that after i've differentiated 2x * y' ?
Cheers :)
Assume a solution exists. Since it exists, it can be uniquely written as a power series. So write y as a generic power series, then substitute it into the differential equation. Combine like terms then use the initial conditions.
