Not what you want to wake up to.
Permabanned
5 Jun 2010
Some delightful little so and so has decided it would be a good idea to throw part of a paving slab through one of our windows.
It must have took some effort to throw that as it is a 1st floor window. The room is about 12 feet long from the window to the wall where the chair is and the part of the slab even went through the blind.
Image needs resizing, but your right, scum with nothing better to do.
Have you peed someone off or do you think its just a random attack?
Dust for fingerprints, find said culprit and install it through their window.
Disgusting :(
You can't get prints of concrete sadly.
Lucky that no one was in there at the time.
I was in there about 30 minutes before it happened.
Judging by the size of that I am not sure they were a 'little so and so' and more likely a 'quite big so and so'.
It was a pretty good effort considering the distance traveled across the room after it hit the blind.
If you find the little toerag are you planning on throwing him a similar distance? Maybe we could have an OcUK competition to see who can get the longest throw.
