Today's deals!
Asus GeForce GTX 680 Direct CU II V2 2048MB GDDR5 PCI-Express Graphics Card @ £249.95 inc VAT
ASUS DirectCU thermal design utilizes all-copper heatpipes so heat is removed efficiently. DirectCU II generates 6X greater airflow yet performs 3X quieter than reference in idle and full load thanks to dual 100mm sound-dampening fans – making for low-noise and high-performance graphics cards.
Acclaimed DIGI+ VRM has been applied via a power design that uses digital voltage regulators to minimize power noise by 30% and enhance power efficiency by 15%, widen the voltage modulation range, and improve overall stability and longevity by 2.5 times longer than reference.
The GeForce® GTX 680 delivers more than just state-of-the-art features and technology. It gives you truly game-changing performance that taps into the powerful next-generation GeForce architecture to redefine smooth, seamless, lifelike gaming.
Immerse yourself in an ultra-smooth gaming experience with exciting new NVIDIA technology advancements like NVIDIA Adaptive Vertical Sync. It’s a fast, seamless way to adjust VSync to your current frame rates for maximum playability.
Features:-
- All new DirectCU thermal design utilizes five all-copper heatpipes and 20% bigger dissipation area, achieving 20% cooler and 14dB quieter performance than reference
- Acclaimed DIGI+ VRM with 10-phase Super Alloy Power technology delivers precise digital power and enhanced overclocking headroom.
- VGA Hotwire allows you to plug and solder wires on the card’s voltage regulators and accurately read and control Vcore, Vmem, and PLL voltages on a hardware level
- GPU Tweak utility helps you modify and tune boost clock, power target , and fan performance via an intuitive interface
Specification:-
- Core Clock: 1006MHz (GK104)
- Core Boost Clock: 1058MHz
- Innovative thermal design: Vapour Chamber (Quieter & Cooler than previous generation)
- Memory: 2048MB GDDR5
- Memory Clock: 6008MHz (Effective)
- Memory Interface: 256-Bit
- Processing Cores: 1536
- Shader Clock: 2012MHz
- Bus Type: PCI-Express GEN 3.0 (Backwards compatible)
- Display Connectors: 2x Dual-Link DVI-I, 1x HDMI 1.4a & 1x Displayport
- SLI Ready (Upto 3-Way SLI Supported)
- HDCP Capable
- DirectX 11 Support
- OpenGL 4.0 Support
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- NVIDIA Surround Enabled
- Lower power consumption (Maximum consumption 195 watts at stock speed)
- 2x 6-Pin PCI-E Connectors required
- Card Dimensions: 270*111.15*38.75 mm
- With FREE Splintercell Blacklist PC Game
- Warranty: 3 Years
Only £249.95 inc VAT.
ORDER NOW
Kingston HyperX 3K SSD 120GB 2.5" SATA 6Gb/s Solid State Drive - Na'Vi Limited Edition (SH103S3/120G-NV) @ £81.98 inc VAT
Natus Vincere or Na`Vi (lat. - born to conquer) is a leading e-Sports multigaming club. It is the first team in Counter-Strike history to win three major tournaments in one calendar year - Intel Extreme Masters, Electronic Sports World Cup and World Cyber Games 2010. In 2011, Na`Vi.DotA won the $1 million grand prize at The International, the first ever Dota 2 tournament. Na`Vi attended 52 tournaments in 25 countries on 3 continents over past 2 years. With this wealth of experience which comes from these type of athletes traveling the world and using a wide array of gear, overtime Na`Vi know what works and know what hardware will give any user the edge
Specification:-
- 95k IOPS
- Capacity: 120GB
- Controller: SandForce SF-2281
- Maximum Read: 555MB/sec
- Maximum Write: 510MB/sec
- Max I/O Per Second (IOPS): 95000 IOPS (4KB File, READ)
- NAND Flash: Multi-Level Cell (MLC)
- Interface: SATA-III / 6Gbps (Backwards compatible with SATA-II / 3Gbps)
- TRIM Support (Requires Windows 7)
- Dimensions: 1.77 x 12.95 x 18.4 cm
- Warranty: 3 Years
Included in the box
- SSD 2.5" to 3.5" adaptor in metalic blue
- Mounting screws
Only £81.98 inc VAT.
ORDER NOW
Features:-
Specification:-
- HDCP Capable
- PhysX Enabled
- CUDA Enabled
- 3D Vision Enabled
- Warranty: 3 Years
ORDER NOW
Specification:-
- 95k IOPS
- Capacity: 120GB
- Warranty: 3 Years
Included in the box
- Mounting screws
ORDER NOW
