£800-£1200 Gaming spec
hey guys thanks for all the great ideas i have a few questions
but first I don't feel confident putting any sort of watercooling systems in this build.
what would a computer at the lower end of the price range look like?
are there any difficulties involved with having both the SSD and Hard Drive ?
No worries fella.
The refurb'd H100 offers very decent cooling for the price. I added it partly because of that but also to show the cases I picked can mount these coolers, the cheaper cases don't really allow this is an option. The CLCs are sealed units so aren't true watercooling it just gives the look whilst offering good thermal properties.
SSDs offer amazing boot times and reduce the load times of games installed to them. They are a bit of luxury item but we will try to fit them in if the budget allows it.
You seem dead set against windows 8 but I will point out there is a trial you can use for free for 3 months. Knocks £80 off the budget whilst you make up your mind over it should you choose to do so.
Recently the prices of the 7950 and 670s have been slashed. The minimum GPU I would recommend is a 7870LE. These GPUs are closely related to 7950s (being Tahiti cored too) so OC'ing them allows them to trade blows with a stock 7950. With the 7950 price drop they aren't the bargain they once were.
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x VTX3D HD 7870 Black Boost Edition 2048MB GDDR5 PCI-Express Graphics Card £161.99
1 x IIyama Prolite E2273HDS 22" Widescreen LED Monitor - Black £119.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £109.99
1 x Microsoft Windows 7 Home Premium SP1 64-Bit - OEM (GFC-02050) £83.99
1 x Patriot Viper "Black Mamba" Generation 3 8GB (2x4GB) DDR3 PC3-15000C9 1866MHz Dual Channel Kit (PV38G186C9K) £65.99
1 x Corsair Builder Series CX 500w Modular '80 Plus Bronze' Power Supply (CP-9020059-UK) £49.99
1 x Seagate Barracuda 7200RPM 1TB SATA 6Gb/s 64MB Cache - OEM (ST1000DM003) HDD £49.99
1 x Corsair Carbide 200R Compact ATX Case - Black £47.95
1 x Logitech G500 5700DPI Gaming Mouse (910-001262) £39.95
1 x Microsoft SideWinder X4 Gaming Keyboard - Retail (JQD-00006) £32.99
1 x Thermalright True Spirit 120 REV A (BW) Performance CPU Cooler £24.98
1 x LG GH24NSB0 24x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £1,019.28 (includes shipping : £13.75).
Still a respectable gaming build which alllows OC'ing of the CPU and GPU to improve performance. Of course you can tweak as you see fit. I've used a decent keyboard and mouse but this is chipping into the budget some what.
It might be best to pick a case you like and work from there. For a single 1080P 60Hz panel running dual GPUs is overkill really so a 500W PSU is ample and saves cash on the mobo too.
YOUR BASKET
1 x Antec GX 700 Rugged Gaming Case £59.99
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £41.99
Total : £977.17 (includes shipping : £24.45).
This rugged Antec can still mount 240mm rads and has a green military theme. I've ditched the OS as I mentioned the Windows 8 trial.
I wish you all the best with the build. You can use THIS to post a basket of what you think you might like to buy :)
EDIT
I stupidly used the 1866Mhz kit when the 2133Mhz is priced the same, I clicked on the wrong kit. Obviously change that I'm not going to edit the baskets now to include it.
Hey thanks so much for answering my question i will keep the SSD
I have tried window 8 before and was frankly confused a lot of the features i was used to where either not there or well hidden and i would be much more comfortable helping my little brother out with problems on an OS i know how to use.
thanks for showing me some of the cheaper builds even they look impressive i will post what i think i'm going for it'd be great if you would notice any problems with it when i post it.
Hey guys.
Thank you all for your great builds.
I sat down today with my little brother so that he could choose the aesthetic parts of the build for himself as it is him that has to use it almost daily and he wants it to look "awesome" But when looking at the cases we found one he liked (took ages) but it didn't come in green so I came up with a new build using mostly parts you guys recommended but again i did not choose the liquid cooling for the processor.
So here is the build please look it over and by all means tell me which parts do not work together.
YOUR BASKET
1 x Asus GeForce GTX 670 DirectCU II OC Gamer 2048MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £197.99
1 x Iiyama Prolite X2377HDS 23" Premium IPS Panel Widescreen LED Monitor - Black £131.99
1 x Gigabyte Z87-HD3 Intel Z87 (Socket 1150) DDR3 ATX Motherboard £91.99
1 x NZXT Phantom 410 Enthusiast Midi Tower Case - Black/Orange £84.95
1 x Plextor M5S 128GB Solid State Drive - (PX-128M5S) £79.99
1 x Corsair Builder Series CX 750W '80 Plus Bronze' Power Supply (CP-9020015-UK) £67.99
1 x Kingston HyperX Predator 8GB (2x4GB) PC3-17066C11 2133MHz Dual Channel Memory Kit (KHX21C11T2K2/8X) £65.99
1 x TT eSports Challenger Pro Gaming Keyboard £47.99
1 x Xigmatek Prime SD1484 CPU Cooler with 140mm Fan £39.98
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £16.99
Total : £1,197.77 (includes shipping : FREE).
IPS panels aren't great for gaming as such fella. The PSU is OTT for the mobo really and having a modular unit would be nice. RAM is also looking to be stupidly tall with those heatspreaders. The HD3 isn't a bad mobo but the D3HP is better and would OC better.
If it was my lil bro I'd probably consider this seeing as he doesn't seem to mind a bit of blue to "tart it up".....
YOUR BASKET
1 x MSI HD 7950 Twin Frozr III Boost Edition 3072MB GDDR5 PCI-Express Graphics Card **NEW REVISION** with FREE GAMES £189.95
1 x Iiyama Prolite E2481HS-B1 24" Widescreen LED Super Slim Bezel Monitor - Black £143.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £86.99
1 x BitFenix Ronin Tower Case - Black £69.95
1 x Avexir Core Blue Series 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (AVD3U16000904G-2CW) - Blue Light £59.99
1 x Alpenföhn Matterhorn CPU Cooler Rev. B £47.99
Total : £1,197.23 (includes shipping : £13.75).
The Ronin has a nice big window panel to show off the colour coded internals. Bitfenix do coloured strips for their cases to inject colour into them, I can't see that OCuk stock them for the Ronin yet but they could be added later if you wanted to.
Thankyou Hono
I was unsure about the height of the ram when looking at it and i decided to go with a bigger is better approach to the PSU but if its unnecessary i will of course scale that back
I will ask my little brother what he thinks of the case & keyboard as i see you have used the same mouse i did if change anything i will let you know but if thats the best internals for my price bracket then i'd be happy to stick with what you suggest expect a revision soon.
YOUR BASKET
I would go with this HONO and DOOM are two of the best speccers the forums have if they have suggested it, it will surely do well for your little brother and although looks are a personel choice your are always going to have to comprimise one way or another to get the best of both worlds :cool:
^ I really like that Hono. :)
EDIT: what the hell are you doing up at quater to 5 anyway? :)
Cheers bud :) There is no rest for the wicked ;)
Thankyou Hono
I think you'll find you used the same mouse as me ;) I've stuck with that mouse and keyboard combo through and through. They are not the cheapest options but good quality.
It all comes down to balance really bud. 500W is ample for a single GPU setup to be honest. The Plextor SSD isn't bad but the write speeds are quite low, at the time for the sake of another few quid the Toshiba or the Sammy Evo would have got my vote.
Prices have changed now due to the weekly offers, you'll notice the CX500M PSU is no longer on offer. There is a cheaper Matterhorn cooler but the fan isn't blue. The Plextor SSD is now £90 so it's mental to pick that over the Evo, the Toshiba is now £95 so we can forget that too.
I did my best to balance good value performance parts (with good warranties) and tried to make the rig look "Awesome" without spending over the odds to do so. There is always some wiggle room in spec'ing. I look forward to seeing your next basket now you've had some practice, the offers are valid for another week so you have time to tweak things around :)
That Antec is Seasonic made isn't it?
Correct.
http://www.hardwaresecrets.com/article/Antec-High-Current-Gamer-520-W-Power-Supply-Review/1399
Well worth the extra over the CX500 modular even if it does mean missing out on some modular cables (luckily the Ronin has plenty of room to hide the extra cables).
In fact here's a great spec.
YOUR BASKET
1 x MSI GeForce GTX 680 OC Twin Frozr 2048MB GDDR5 PCI-Express Graphics Card £215.99
1 x BenQ GW2460HM 24" Widescreen LED Professional Slim Bezel Monitor - Black £149.99
1 x Gigabyte Z87-D3HP Intel Z87 (Socket 1150) DDR3 ATX Motherboard £103.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-21300C11 2666MHz Dual Channel Kit (TXD38G2666HC11CDC01) £65.99
1 x Antec High Current Gamer 520W '80 Plus Bronze' Power Supply £59.99
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £51.95
1 x Corsair Hydro H100 Extreme Performance Liquid CPU Cooler *Manufacturer Refurbished Unit - 90 Day Guarantee £44.99
1 x Corsair Raptor M30 Gaming Mouse (CH-9000042-EU) £34.99
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £11.99
Total : £1,228.26 (includes shipping : £13.75).
• Faster RAM, Haswell integrated memory controller loves quick RAM.
• GTX680!!!!
Hey guys thank you for your new builds I'm uncertain about using AMD over intel as i have only ever used intel and have been very pleased with them. are they better for gaming computers or just different ?
I will be posting another build later today and will be looking to purchase before the end of the week.
Here it is guys the final build .... unless i missed something the graphics card suggested by lots of you is sold out so i went for a better one for a little over budget i will be buying this as soon as possible unless there are any flaws.
YOUR BASKET
1 x Asus GeForce GTX 760 DirectCUII OC 2048MB GDDR5 PCI-Express Graphics Card £203.99
1 x BenQ GW2460HM 24" Widescreen LED Professional Slim Bezel Monitor - Black £169.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £84.95
1 x Western Digital Caviar Blue 1TB SATA 6Gb/s 64MB Cache WD10EZEX - OEM ** Single Platter ** HDD £54.95
1 x Phanteks PH-TC12DX CPU Cooler - Red £44.98
1 x OcUK 20x DVD±RW SATA ReWriter (Black) - OEM £13.99
Total : £1,243.72 (includes shipping : £12.50).
I am using air cooling instead of liquid for the CPU and that won't change I'm old fashioned like that.
Cant see any flaws with that apart from GFX card choice, there are so many to pick from,
YOUR BASKET
1 x Asus GeForce GTX 670 DirectCU II 4096MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £209.99
1 x Asus GeForce GTX 670 DirectCU II OC Gamer 2048MB GDDR5 PCI-Express Graphics Card **FREE SHIPPING** £199.99
1 x KFA2 GeForce GTX 670 OC 2048MB GDDR5 PCI-Express Graphics Card (67NPH6DV5ZVX) £197.99
Total : £607.97 (includes shipping : FREE).
GTX670's are equal to a GTX760 - http://www.anandtech.com/bench/product/854?vs=830 - one of the Asus cards above even has 4GB Vram.
YOUR BASKET
Total : £200.75 (includes shipping : £9.00).
Or this 7950 which has free games.
