Get some case fan air filters, It might prevent this type of problem for you
Taking a High end GFX card is easy but doing it properly will take a couple of hours, You just can't leaver off backplates stuck with thermal pads etc..although people do (and if you need to ask why, you definitely should not be doing the job) Best avoid !
The dust got in there through the fan, Get an air line and carefully blow it out in the reverse direction, keep the temps sensible and you won't burn off the cheap thermal paste also
