Sorry, i didnt see that bit. A 20mm axle hub will work with a normal QR with adapters. If you dont need the 20mm compatibility (if you had a 2nd bike or plan on upgrading your forks soon) then it would make more sense to just get QR wheels. These will fit on your bike with adapters though.
If its a normal qr it'll be 9mm not 15 or 20mm.
Pull the qr skewer out of your current wheel, should be obvious which one it is or measure it if you have to
If you're measuring it, remember that the size refers to the axle, not the skewer (the skewer will be 2-3mm). The 9mm axle on a standard QR doesnt come out of the hub. A 15mm or 20mm axle will come out, so you can measure the axle.
