hey guys im having some issues with my build and i would like some advice
so basicly i got my a corsair 500r ans the h110 water cooler the way i have it set up is i have the 2 fans in the top cover of the case and the rad is inside the case i want to set it up in push pull but there just isnt enough room for me to get the fans on the bottom of the rad, so i had a little look around the internet and found some half depth fans wich do look promising my question is before i buy them and start messing around does anyone know if that would get the job done? and if a half depth fan would push enough air to even make it worth it? and also i dont know if im just looking in the wrong places but i cannot find a half depth 140mm static pressure fan
thanks
thanks
