- 27 Dec 2009
- Gillingham, Kent
I'm very happy with the performance from my 7970's, but after using an Accelero on a single 7970, I've been a bit spoilt and fancy going for a quieter or cooler setup. Currently I have GPU1 as a Gigabyte Windforce 7970, and GPU2 is a launch week VTX3D 7970 with an Accelero fitted. On Sleeping Dogs the cores will hit 85/65 maximum (I use this as my worst case game, Just Cause 2 hits 75/60 max for example), so I'm happy enough with temperatures but if I could shave off a couple of degrees I won't exactly be unhappy. Before anyone starts telling me my GPUs are hotter than they should be, bear in mind I'm running the cards overclocked slightly to 1050/1500 and at 5760x1080 across 3 screens (with a 4th screen at 1600x1200 that I use for monitoring software, email, etc) and if I drop down to 1 screen I do get the kind of temperatures they quote in 7970 reviews.
My options are:
Install an Accelero on the Windforce - this appeals for aesthetic reasons as my 2 GPUs will look the same, and I know from experience that it'll be quiet. My concern is that on my motherboard an Accelero on GPU1 will be almost touching GPU2 so won't get much air to breath. I've tried swapping my cards around to test and playing Sleeping Dogs, and after a while the Accelero hit 85C on the core, and 110C on VRM1 and the frame rate dropped. The Windforce has a different VRM setup (the cooler's different and would work under an Accelero, but the card doesn't give VRM temperatures to any software to monitor them), but I don't know if the Windforce would act the same in this position or if it would be OK.
Fit an all-in-one water cooler to the Windforce - this appeals a lot to my tinkerer/geek brain. I just fancy trying it and it would be cool. However, I don't have a spare AIO cooler, so would need to buy one and I don't know what size shim I would need. One of the Dwood brackets would be perfect for this option, but he seems to have stopped making them so I'd have to rely on cable ties. The refurb H80 is appealing for this, but I'd probably need another fan mounted on the card to cool VRMs so was thinking this might be good for that: http://www.overclockers.co.uk/showproduct.php?prodid=HS-031-AL but adding these together comes to the same cost as an Accelero.
Suck it up Princesss - just live with the mismatched GPUs, and the noise from the Windforce at 100%. This is the cheapest and safest option, and the only known quantity, but it doesn't scratch the tinkering itch or improve anything.
Would genuinely appreciate any advice, input or opinions from anyone here. Thanks.
My options are:
