Following discussion with a friend after seeing a very elderly gentlemen smoking last weekend, we got onto the topic of 'when is the cut off point?'Looks like we have a newbie climbing the ladder
wont be long till your looking for variable wattage devices Tommy
Although I shan't be going for the pink pack
I'm noticing that Fasttech has a few mentions in this thread. I'm tempted to buy a Vamo and a couple of Kanger Pro Tanks from them but the prices seem to good to be true. I expect that delivery might take some time but I'm sceptical as to whether I will receive genuine products.
Are those of you who have orederd from them happy customers?
Anyone after custom tailored juices, without the high price tag, you ought to give www.yaeliq.com a try. Been chatting to the owner of this family business and placed an order. Checked the tracking site and it's already left Israel!
EMS site.How did you check the tracking? There is nothing on the site.
cant find the mini protank cheaper than fasttech anywhere else.
why so cheap!?
After much thought I need to invest some money into alternatives to get that nicotine 'hit'!
Thanks ever so, will order right awayAlthough I shan't be going for the pink pack
Is the same site favoured for liquids? If so, any recommendation on flavour? Will probably go for standard menthol or a minty version of something, and then something a lot more exotic, say vanilla or chocolate!
Dont look Allnamestaken lol
For anyone after a Roller SS-IM mech mod, one on AAEC for £80
http://allaboute-cigarettes.proboards.com/thread/28054/roller?page=1&scrollTo=510329
Also an Evic with no battery going for £35, cheap imo on AAEC as well
why so cheap!?
Vapeland.com service is great, but juices are just re labelled Hangsen/Liqua (Chinese mass produced, ok but not excellent). Www.joosejuice.co.uk do very reasonable samples (£1.49 per 10ml) and BOGOF on 30ml bottles (so 60ml for £7.25).
If you want to try something more elite, Scope's Apple Tart (and his other flavours) is truly excellent, but not cheap at £12 per 30ml, plus postage. You'll need to ask for his email address.
Otherwise, Fasttech.com do supremely cheap Hangsen and Liqua flavours, under £4 delivered per 50ml.
Once you know what strength and ratio of PG/VG you need, you'll be ordering tailored juices from Israel at $18 per 100ml - www.yaeliq.com
The trick is to try as many different flavours until you find your perfect All Day Vape, then buy a huge amount of PG/VG and Nicotine base and flavour concentrate to create your own!
Happy Vaping
We and I will do our best to help you sir![]()
Ive noticed I can tip this Aga t2 down and it wont leak unless I leave it there for quite a while if it even leaks at all. The surface tension on the fill hole stops it from leaving the tank lol. I might try another wick type on the aga t2.
How is the Kayfun lite? is it worth the money?
I could probably buy x5 Protank II's or Davides for less than 1 of them,
You using cotton pads? i have seen cotton used before
but I never liked the ProTank. I don't like its airy draw. The KFL can be a right pain if not coiled right, as it can give very muted favour. I'm happy with the KFL but all depends on your budget. It's a bit like a Vamo isn't 5 times as good as ProVari. The Vamo will last a few months but the ProVari is like a tank. You are paying for quality and aesthetics plus it doesn't leak.
