Hi guys, been having some issues with my new haswell build
i set the system up and have been ocing to test and default to test up untill recently i never thought about testing the memory untill in a few games i got a few freeze ups.
Sooooo i downloaded the latest beta 5.0RC1 memtest86. not sure if this build is stable or not on haswell as some dodgy stuff keeps happening.
when running the test im getting errors on test 6.
funny thing is when i run the test it will pass with no errors 2 times then it will start showing errors.
this is at the memorys default XMP profile no oc on it or timings.
but if i run my system default optimized defaults then enable xmp and run the test it will pass the test without errors. but sometimes it will show errors and others not.....
i can not pinpoint the issue as it could be cpu or mobo or memory as those are the 3 things thats new in my system as of recently.
wich points me to beleave its my uncore thats causing it, but i cant seem to get rid of the issue
any advice guys about trying to stabilize uncore... though the errors on the memory are there even on 4.5ghz cpu/4.0ghz uncore
settings i have tried that still cause the errors to show up.
cpu vin external @1.9v
cpu vcore @1.260v
vring @1.2v
system agent @+0.25
digital & analog @+0.25
I dont know what else to do...
cpu vcore @1.260v
vring @1.2v
system agent @+0.25
