***The Vapers Lounge***
Status
Not open for further replies.
for apple tart, try
flavourwest dutch apple pie and some PA cinnamon danish?
or get some PA apple, capella pie crust and cinnamon, its going to be trial and error until u get a mix u like
Lemon and lime hardly needs steeping mate, 24 hrs i usually do it, still vaping it now tbh its my all day vape for the last couple of months.
Capella Lemon and Lime @ 20% (might be worth starting at 15%)
EM at 1%
thats it Hamster, simple but nice imo, try a 5ml mix first and see what u think
oh and i done it 60/40
I mixed it up at 15% first time but 20% is better. I just drip in the EM so not 100% sure the % It is such a simple flavour it doesn't need long steeping. Bit like Sprite imo I mix everything at 70/30 so pretty close. Not really adding anything just another vote for this.
Must admit I'm intrigued by the brew-it-yourself aspect but don't have the first clue where to buy anything in terms of liquid nicotine, PG/VG, flavours etc.
Agreed, its a simple recipe but very nice especially this time of year.
I usually do 2 drops per 10ml with sweetner
Glad you said that as I mixed it at 20% :D
If you want, trust my your email and I can forward the email I sent to Redmogg. Contains the basic info to get your started.
You probably already know j.col, VG is dirt cheap from Boots. It's sold as glycerin (Care brand or Boots value brand) but is 100% vegetable based. Usually £1.29 for 200ml.
i know but keep forgetting lol
Think I HAM and do full 50ml custard boat, don't want to waste it doing little samples.
Be VERY careful, i made the same mistake, i made a big 50ml mix and after 4 weeks it was just ok, i never added the french vanilla deluxe, so once i added that i had to wait another 2 weeks steeping lol, and tbh i was lucky to rescue it.
Personally i would do a few 5ml mixes, trying different ratios of VC, DDL and FVD,
They will still be vapeable after steeping, but u will find one u like best, then make a 50ml batch of that one.
But keep carefull records of what %'s you used
The Daily Fail has screwed us once again with an articled titled "electronic cigarettes as bad as smoking" when neither the study they cite (which they never read fully) makes no such claims, and that's before you even get to the fact the study isn't even in a peer reviewed journal. Gah!
Comes to something when the paper it's printed on isn't even worth wiping your bum with!
Recieved my ego-T v3 starter kit today and just had my first try! A great hit and tastes great! (blueberry)
Made sure I tightened everything up in the clearomiser prior to doing so, having opened it up it soon becomes clear what people are referencing to when discussing wicks/springs etc. :)
Do I need to keep it horizontal the entire time, or as best I can? Am concerned about the liquid seeping out of the tip although this may just be over precautious?
Status
