Hello.
I was all set to buy the MSI 7950 Twin Fozr III, then I saw the HIS come up in this week only.
Which is the better card? I've had a look at some reviews. Seems the MSI can clock higher, but not by much. The MSI is thinner, but that'll only really come into play if crossfiring, which I'm not planning on doing.
Do both dump heat into the case? I've read mixed reports and not sure if the HIS is designed to pull cool air from outside, or dump hot air outside?
Really just after a general consensus. I'm assuming the never settle bundle is also included as well as the new gold pack?
Thanks
Thanks
