- 9 Dec 2009
- Bristol
Hi
Building a home system for a friend who will be using it many for internet shopping, backing up family photos and doing his invoices.
£150 budget, was going to look at buying some 2nd hand 775 gear off MM but want to look at the possibility of buying new components with integrated graphics as they wont be gaming.
Also not going to bother overclocking it as I'll be the one going round there to sort it if it fails, but if there are any cheap combos which are begging to be tweaked I'll do it.
We already have:
Midi-sized case (just going to use the old one)
optical drive (but IDE so might have to get SATA)
4gb DDR3 ram
keyboard and mouse (ps2)
17" monitor
So just need:
Mobo to fit midi sized case (mini ATX?)
CPU (ideally with integrated graphics)
PSU
Hard drive (500GB minimum, ideally 1TB)
Optical drive (If required)
ps2 to usb adaptors
I've not done anything with AMD CPU hardware since 2005 and haven't built anything smaller than standard ATX sized systems so would appreciate some help on what to get.
We already have:
4gb DDR3 ram
17" monitor
So just need:
PSU
ps2 to usb adaptors
