** THE GREATEST CASE EVER MADE RETURNS - UPDATED, BETTER THAN EVER, EXCLUSIVE TO OCUK **
rjk
rjk
Caporegime
8 Aug 2007
Ladies and Gentlemen
It gives me immense pleasure to reintroduce you to the greatest computer chassis ever created.
I am fortunate enough to have been able to build an extreme PC in this wonderful case back in X58 days when 12GB of Standard Dominator DDR3 cost £900 and a 60GB Intel SSD was £600 :D
I can honestly say without a shadow of a doubt that the 343B is the greatest case ever made. Now it has been improved further, with modernised options like USB3.0, Improved radiator mounts, SSD brackets and eSATA
The big change is the adoption of the HTPX form factor meaning that 343B is the ideal case for SR-2/SR-X configurations.
The original 343B was a case designed for server use that when modified, lent itself well to Watercooling application. This is all change and this new revision supports mental WC configurations out of the box.
Add the usual Lian Li quality of sleek brushed aluminium and premium finish, this is a high end enthusiast chassis not to be missed.
Our ETA is around mid October.
Gallery:
Lian Li PC-343B Cube HPTX Housing - Black @ £284.99 inc VAT
The Lian-Li PC-343B Modular Aluminum Cube Case; this is without a doubt the most complicated case Lian-Li has ever built. It allows you to setup different optional configurations on almost every inch of the case. One can install up to 18 different single 5.25" bay devices, or 30 Hard Disk Drives*, or a dual 120mm Radiator*, or a triple 120mm Radiator, up to two power supplies, up to 11 120mm fans*, and more!
The Lian-Li PC-343 modular design means that it is perfectly suited for any project that needs lots of space. Of course since it is built by Lian-Li, you can expect that perfect aluminum finish that lends elegance to any system.
Features:-
- Removable top panel with optional plates
- Built-in multi-media I/O ports
- Optional Fan Filters
- 5.25" to 3.5" Floppy Bay Converter (optional)
- Removable Rear Mount Hard Disk Drive Cage (optional)
- 5.25" to 3.5" Hard Disk Drive Cage Converter (optional)
- Anti-Vibration rubber mounts for Hard Disk Drives
- Optional dual power supply plate
- Optional Liquid Cooling Radiator mounts
Specification:-
- Manufacturer Number: PC-343
- Dimensions: 460 x 520 x 565 mm (W x H x D)
- Material: Aluminum
- Color: Black
- Weight: 9.3 kg
- Form Factor: HPTX, ATX, Micro-ATX
Fan (optional):
- 4x 140 mm (cover)
- 3x 120 mm (rear)
- 2x 140 mm (bottom)
- 2x 140 mm (sidewall)
Drive Bays:
- 18x 5.25 inch (external)
- 4 x 2.5 inch (internal)
- Power supply (optional): Standard ATX 1x (tool-less, filter)
- Expansion slots: 11 (Tool-less)
I / O Panel:
- 4x USB 3.0
- 2x Audio
- 1x eSATA
- Maximum video card length: 400 mm
- Maximum CPU cooler height: 230 mm
Only £284.99 inc VAT.
ORDER NOW
I'm struggling to work out what the second half is for. Motherboard on one side, lots of optical bays - all good. But then there's another enormous space in the other half of the case. What are people expected to put there?
I like it, it addresses the issues the Lian Li PC-D8000B had. Motherboard has now been move mid, optional plates as standard instead of looking for stock or special ordering.
Sadly it is still huge. Would have been great to see a mix of the Caselabs M8 and that Corsair abomination people pretend to love.
Something like this Lian Li, on a smaller scale with motherboard one side and HDD's, optics and PSU on the other would be nice.
