Hi there
Some epic monitor deals for this weekend, check them out:-
Samsung S22C300BS 22" Widescreen LED Monitor - Rose Black @ £99.95 inc VAT
Experience amazing new levels of colour, brilliance and picture quality through the very latest in Mega Dynamic Contrast Ratio. Samsung SC300 monitors deliver images so real-to-life that it will transform your whole viewing experience. Packed with breathtaking 5000000:1 contrast ratio, the highest level currently available, the SC300 monitor ensures that blacks are at their absolute darkest and (with pristine whites) colours are at their brightest. You will immediately notice the crystal clear picture and its unbelievable intensity. It is like an explosion of colours and leaves other screens seeming dull in comparison. So, take your viewing pleasure to the next level with Samsung Mega Dynamic Contrast Ratio – and enjoy your multimedia content with the professionalism it deserves.
Eco saving makes saving energy easy. It adjusts the brightness of your Samsung monitor based on how much energy you want to save. And with the choice of three energy saving modes (50%, 25% and Power Saving off), you can really tailor your monitor use to meet your own personal needs. Samsung’s commitment to saving energy is designed to help both you and the environment, and with up to 50% saving on consumption, you can really make a positive impact on your eco footprint. Take the effort out of saving energy and take control with Eco saving.
- 21.5" (16:9)
- LED Technology
- Resolution: 1920x1080 (True HD)
- Contrast Ratio: Dynamic: Mega DCR (Static: 1000:1)
- Brightness: 250cd/m2
- Response Time: 5ms
- Colour Support: 16.7M
- Input Connection: 1x Analogue & 1x DVI
- Stand type: Simple, tilt function only
- Wall Mount: No
- Set Dimension with Stand (WxHxD): 512 X 385 X 197 mm
- Set Dimension without Stand (WxHxD): 512 X 311 X 53 mm
- Set Weight with Stand: 3.0 kg
- Cables: D-Sub Cable included
- Apple & PC compatible
- 3yr Warranty
Was [£119.99] Inc. VAT
Only £99.95 inc VAT.
ORDER NOW
Asus VE247H 24" Widescreen LED Multimedia Monitor - Black @ £141.95 inc VAT
Dynamically enhances the display’s contrast by adjusting the luminance of the backlight to achieve the darkest black and brightest white – delivering lifelike images. Enter a spectacular world of colors with Full HD 1080p (1920x1080) support and HDMI port. Quick response time of 2ms (GTG) eliminates ghosting and tracers for more fluid video playback. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 5 preset video modes (Scenery, Theater, Game, Night View, and Standard) can be selected via a hotkey.
Features:-
- Display Panel Size : 23.6"(59.9cm) 16:9 Wide Screen
- True Resolution : 1920x1080
- Pixel Pitch : 0.272mm
- Brightness(Max) : 300 cd/?
- ASUS Smart Contrast Ratio (ASCR) : 10000000:1
- Viewing Angle (CR?10) : 170°(H)/160°(V)
- Response Time : 2ms (Gray to Gray)
- Display Colors : 16.7M
- Video Feature Trace Free Technology
- SPLENDID Video Intelligence Technology
- SPLENDID Video Preset Modes : 5 Modes
- Skin-Tone Selection : 3 Modes
- Color Temperature Selection : 5 Modes
- HDCP support
- Audio Features Stereo Speakers : 1W x 2 Stereo RMS
- Convenient Hotkey SPLENDID Video Preset Mode Selection
- Auto. Adjustment
- Brightness Adjustment
- Volume Adjustment
- Input Selection
- I/O Ports Signal Input : HDMI 1.3,D-Sub,DVI-D
- PC Audio Input : 3.5mm Mini-Jack
- AV Audio Input : HDMI 1.3
- Earphone jack : 3.5mm Mini-Jack
- Signal Frequency Analog Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Digital Signal Frequency : 30~83 KHz(H)/ 50~76 Hz(V)
- Power Consumption Power Consumption < 35 W
- Power Saving Mode < 1 W
- Mechanical Design Chassis Colors : Black
- Tilt : +20°~-5°
- VESA Wall Mounting : 100x100mm
- Security Kensington lock
- Dimensions Phys.Dimension(WxHxD): 569.4 x409.7x201mm
- Box Dimension(WxHxD): 638x 480 x175mm
- Weight Net Weight (Esti.): 4.4 kg
- Gross Weight (Esti.): 7.1 kg
- Accessories DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
Was [£149.99] Inc. VAT
Only £141.95 inc VAT.
ORDER NOW
Asus VN247H 24"Widescreen Super Narrow Bezel LED Monitor - Black @ £164.99 inc VAT
The ASUS VN series features compact dimensions- this 23.6” display has a super narrow bezel less than 1cm thick, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN247H is also VESA wall mount compatible, and has the capabilities to be a stunning multi-screen solution.
VN247H leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI and D-sub inputs. An Ultra-fast 1ms gray-to-gray response time and trace free technology deliver realistic moving visuals and a blur-free multimedia experience. With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 250cd/m² brightness, the VN247H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. Aspect Control function allows users to select a preferred display mode among Full and 4:3 for true-to-life gaming or movie watching without any data loss or image distortion.
VN247H comes with rich connectivity including Dual HDMI and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey. ASUS includes its exclusive QuickFit Virtual Scale feature with the VN247H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size.
Features:-
- Ideal for a multi-screen solution with a super narrow frame
- Best for work and play with Full HD 1080p visual quality and rich connectivity including dual HDMI and D-sub inputs
- Ultra-fast 1ms (gray-to-gray) response time for amazingly blur-free multimedia experience
Specification:-
- Panel Size: Wide Screen 23.6"(59.9cm) 16:9
- True Resolution: 1920x1080
- Full HD 1080P: Yes (support 1080i/p by 1:1)
- Pixel Pitch: 0.272mm
- Brightness(Max): 250cd/m
- ASUS Smart Contrast Ratio (ASCR): 80000000:1
- Viewing Angle (CR?10): 170°(H)/160°(V)
- Response Time: 1ms SUPER-FAST Response time
- Display Colors: 16.7M
- Signal Input: 2x HDMI & 1x D-Sub (DVI-D Supported via HDMI-to-DVI cable)
- Stereo Speakers: 2W x2 Stereo RMS
- VESA: 100x100mm
- Kensington Lock: Yes
- Phys. Dimension with Stand(WxHxD): 548.6x394.9x194.2mm
- Weight: 3.7kg
- Warranty: 3yr
Was [£169.99] Inc. VAT
Only £164.99 inc VAT.
ORDER NOW
Asus VN248H 24"Widescreen Super Narrow Bezel LED Monitor - Black @ £169.99 inc VAT
The ASUS VN series features compact dimensions- this 23.8” display has a super narrow bezel of just 1cm, bringing a broader and better vision without compromising on style and comfort. Its pedestal boasts a sleek concentric circle design and the rear bezel comes with a textured finish that is scratch-proof. The VN248H is also VESA wall mount compatible, and has the capabilities to turn into a stunning multi-screen solution.
The ASUS VN248H features AH-IPS (Advanced High-Performance In-Plane Switching) display technology for superior color accuracy, a brighter image from increased backlight transmission and lower power consumption. VN248H leads you to enter a big and spectacular world of colors with Full HD 1080p (1920x1080) support and rich connectivity including dual HDMI/MHL and D-sub inputs. The exclusive Splendid Video Intelligence Technology optimizes video performance and image fidelity by enhancing color, brightness, contrast, and sharpness. 6 preset video modes (Scenery, Theater, Game, Night View, sRGB and Standard) can be selected via a hotkey.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the VN248H enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life. ASUS includes its exclusive QuickFit Virtual Scale feature with the VN248H, allowing you to preview photos and documents on-screen in their actual size prior to printing. It can be activated via a monitor hotkey, and serves as a highly useful guide to accurately view and edit photos in their native size. VN248H comes with rich connectivity including dual HDMI/ MHL and D-sub so that users could easily connect it to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players and set-top boxes for limitless entertainment and multimedia enjoyment with the built-in stereo speakers.
Features:-
- Best for work and play with Full HD 1080p visual quality and 178° ultra wide viewing angle IPS panel
- ASUS VividPixel Technology for crystal-clear and detail-oriented enjoyment
- MHL (Mobile High-Definition Link) function for Enhanced Viewing from Mobile to Monitor
- Built-in hidden stereo speakers enable audio enjoyment together with true-to-life visual
- I/O port hidden behind the detachable rear cover to keep the back bezel simple and clean
- VESA Wall Mount Standard (100 x 100 mm )
- 25° ( forward 5°, backwards 20° )Tilting Angle
- KENSINGTON Security Lock.
Specification:-
- Panel Size: Wide Screen 23.8"(60.5cm) 16:9
- Pixel Pitch: 0.2745mm
- Viewing Angle (CR?10): 178°(H)/178°(V)
- Response Time: 5ms Response time
- Signal Input: 2x HDMI/MHL & 1x D-Sub (DVI-D Supported via HDMI-to-DVI cable)
- VESA: 100x100mm
- Phys. Dimension with Stand(WxHxD): 554.5x393x194.2mm
- Weight: 4.0kg
- Warranty: 3yr
Was [£179.99] Inc. VAT
Only £169.99 inc VAT.
ORDER NOW
Packard Bell Viseo 243D 24" Widescreen LED Monitor - Black @ £109.99 inc VAT
A great monitor from Packard Bell housed in a traditional high quality monitor exclosure with black finish for a professional look. Great image quality with pixel sharp text from DVI connectivity. Also ideal for gaming with quick 5ms response time.
Features
- Screen Size: 24" Widescreen
- Contrast Ratio: 1,000,000:1
- Brightness: 200cd/m²
- Viewing Angles (H/V): 170°/160°
- Colours: 16.7 Million
- Inputs: 1x Analogue & 1x DVI-D
- Colors: 16.7 M
- HDCP compatible: Yes
- Warranty: 3 Years On-Site
Was [£129.95] Inc. VAT
Only £109.99 inc VAT.
ORDER NOW
Asus SonicMaster MX279H 27" Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers @ £275.99 inc VAT
The Asus MX Designo LED range have an impressive array of features such as frameless and ultra-slim design along with Bang & Olufsen IcePower speakers. The result is an immersive gaming experience with fast response time, incredible contrast with practically a frameless design along with superb quality speakers. Making the MX range ideal for both gamers and those who enjoy watching movies and listening to music on their computers.
Features:-
- 1920x1080 Resolution
- 5ms Response Time
- Matte anti-glare technology
- Contrast Ratio: 80,000,000:1
- Colours: 16.7M
- Trace Free technology
- LED Technology
- AH-IPS with 178/178 Viewing angles
- Frameless, Ultra slim design
- Input Connections: 2x HDMI 1.4, 1x D-Sub (VGA), PC Audio-in jack, Earphone jack
- Aluminum Alloy Decoration
- Touch sensor buttons
- Bang & Olufsen ICEpower Speakers (3W x 2 RMS w/ 5W x 2 Amplifier)
- True high fidelity sound using SonicMaster technology
- Kensington Lock feature
- 3yr Warranty
Was [£299.99] Inc. VAT
Only £275.99 inc VAT.
ORDER NOW
Asus SonicMaster MX299Q 29" Ultra Widescreen Ultra Slim Bezel LED Monitor - Black with Bang & Olufsen ICEpower Speakers @ £399.95 inc VAT
With a display area equivalent to that of two 17-inch (5:4 aspect ratio) monitors placed alongside each other, the ASUS Designo Series MX299Q Ultra-wide 21:9 Cinematic monitor has a display area 33% wider than a Full HD monitor.
The 21:9 aspect ratio gives you more screen real estate for working with multiple windows side-by-side as you would with a secondary display.
The 2560 x 1080 resolution also means there are no black bars above and below the image when watching widescreen 2.35:1 movies and gamers can also enjoy games in immersive cinematic widescreen.
The LED-backlit AH-IPS display has extremely accurate color reproduction that makes the MX299Q ideally suited for both professional and home use. A 178-degree wide viewing angles also ensures minimal color distortion for enhanced screen sharing.
The MX299Q features an ultra-slim profile measuring just 16.4mm at its thinnest point. ASUS Designo Series MX monitors have received numerous design accolades that include the 2012 Japan Good Design Award. The MX299Q also won a 2013 CES Innovations Awards in the Video Displays category.
The ASUS Designo Series MX299Q Ultra-wide 21:9 Cinematic monitor features ASUS SonicMaster audio technology, co-developed with Bang & Olufsen ICEpower®. A combination of advanced audio hardware and professional audio processing, SonicMaster refines every acoustic detail to deliver crystal clear sound with richer, more distinct vocals and wide frequency range. The MX299Q has an embedded Bang & Olufsen ICEpower MobileSound 3 chip that delivers incredible audio fidelity through the two built-in 3-watt stereo speakers for rich and satisfying sound.
Considering its slender form factor, adding powerful audio to MX299Q presented a challenge. Nonetheless, the display features up to 32mm diameter speakers for greater and smoother sound impact with better bass performance. It also offers a resonance chamber of up to 100cc, expanding monitor sound range to new extremes.
A built-in amplifier powers speaker sound reproduction, just like a car engine with more horsepower means better performance can be attained. MX299Q uses up to 5W amplifiers per channel, with speakers embedding large rare earth magnets to generate more powerful and striking sound.
Features:-
- Ultra-wide 21:9 2560 x 1080 resolution LED display with a frameless, edge-to-edge design for pristine cinematic experience and enhanced productivity
- AH-IPS display with 178° wide-view angle for high-quality visual clarity and minimal color distortion
- ASUS SonicMaster Technology, co-developed with Bang & Olufsen ICEpower®, for audio playback that stays true to the source
- DisplayPort, HDMI/MHL, and Dual-link DVI ports for multi-device connectivity
Specification:-
- Panel Size: 29" Super Wide 21:9
- Panel Type: AH-IPS
- Resolution: 2560x1080
- Brightness: 300cd/m2
- Viewing Angles: 178/178
- Colours: 16.7M
- Speakers: 3W x 2 Stereo RMS with Bang & Olufsen ICEpower
- Connectivity: HDMI/MHL, Displayport, Dual-Link DVI-D
- Dimensions: 700.2 x 391 x 215.1mm
- Weight: 5.5kg
- Warranty: 3yr
Was [£419.99] Inc. VAT
Only £399.95 inc VAT.
ORDER NOW
Asus PB278Q 27" Professional LED Multimedia Monitor - Black @ £479.99 inc VAT
Envision bigger with 2560 x 1440 WQHD, packing four times the pixel density of 720p! New premium 16:9 wide-format PB278Q LED displays afford 178° wide viewing angles for better productivity, opening extra multitasking space to fit more windows and projects on-screen. ASUS exclusive Splendid Video Intelligence Technology, QuickFit Virtual Scale, and 100% sRGB fidelity ensure reality-defining color and image accuracy, giving you true “what you imagine is what you create” power. HDMI 1.4, DisplayPort 1.2, and dual-link DVI support WQHD natively, accentuated by room-dominating audio via twin 3W speakers. To help you stay naturally focused, ergonomic design includes tilt, swivel, pivot, and height adjustment, plus streamlined cabling that keeps clutter off your desktop.
The PB278Q features a 16:9 aspect ratio and a LED-backlit 27” WQHD display that provides 109 pixels per inch (PPI), resulting in high quality 2560 x 1440 visuals – equaling four times the resolution of standard 720p sets. It allows users to view greater image detail and do more with an onscreen footprint larger than that of standard displays.
The screen’s 109PPI density means there are 109 RGB matrices within one inch. Generally, the more pixels a display has, the more lighting (or power) those pixels require to achieve the best visuals. However, with advanced LED backlighting on the PB278Q, power and energy savings are no longer compromised, while better visuals are assured.
The ASUS PB278Q provides an ultra-wide 178° viewing angle on both horizontal and vertical planes, thereby minimizing onscreen color shift even when viewed from extreme angles. With its WQHD display, you enjoy 77% more desktop space than a full HD screen to spread out your windows and palettes. It is also about 25% sharper than a generic 27” full HD display, delivering ultra-smooth visuals thanks to 5ms (GTG) response time. This ensures you get lag-free experiences in movies and gaming, with the latter looking more vivid, with all in-game details shown in true color. The ASUS PB278Q is undoubtedly your best choice for work and play.
The PB278Q features a host of connectivity options that include HDMI 1.4, DisplayPort 1.2, and dual-link DVI for native WQHD, plus D-sub for full HD 1080p content transmission. Twin built-in 3W speakers provide quality audio for a completely immersive home theater experience.
With 80,000,000:1 ASUS Smart Contrast Ratio (ASCR) and 300cd/m² brightness, the PB278Q enhances display contrast and sharpness by adjusting backlight luminance to achieve the deepest black tones and brightest whites, resulting in extra-clear visuals that truly come to life.
Driven by a precision color engine that automatically analyzes and determines the nature of your current task, Splendid™ Video Intelligence Technology adjusts display parameters accordingly to ensure color accuracy and image fidelity. Six preset modes (scenery, theater, sRGB, standard, and two user-customizable modes) can be quickly selected via a designated hotkey.
The PB278Q offers a highly ergonomic and smart design that comes with tilt, pivot, swivel, and height adjustments to ensure an always-comfortable viewing and usage experience. Its smart cable management further promotes clutter-free spaces for work and enjoyment.
Features:-
- Stereo Speakers: 3W x2
- Height Adjustable
- Swivel & Tilt Stand
- Screen Size: 27" IPS Widescreen
- Resolution: 2560x1440
- Contrast Ratio: 8000000:1
- Brightness: 300cd/m²
- Viewing Angles (H/V): 178°/178°
- Colours: 1.07 Billion
- Inputs: 1x Analogue, 1x DVI-D, 1x HDMI 1.4, 1x DisplayPort 1.2
- 8-in-1 Card Reader
- VESA Compliant (100x100)
- Dimensions: (WxHxD): 643x552.3x218 mm
- Weight: 8.80kg
- Warranty: 3 Years On-Site (Premium Panel Guarantee)
- Product Review: http://www.tftcentral.co.uk/reviews/asus_pb278q.htm
Was [£539.99] Inc. VAT
Only £479.99 inc VAT.
ORDER NOW
Asus VG278HE 27" TRUE 144Hz 3D Widescreen LED Monitor - Black @ £359.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278HE. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology*, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
With the latest NVIDIA® 3D LightBoost™ Technology, enjoy twice the brightness of conventional 3D technology in 3D mode with zero increase in total energy consumption. It's perfect for dark-color games such as Metro 2033 and Batman: Arkham City. Additionally, the redesigned glasses bundled with NVIDIA® 3D LightBoost™ Technology features a 20-percent larger viewing lens, a light blocking visor for comfortable viewing and more comfortable - gamer-inspired design.
Supported by Trace Free II Technology, the VG278HE is able to double per second to deliver ultra-smooth motion scenes in intense actions, which is over twice faster than generic LCD monitors, delivering ultra-smooth 2D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey.
VG278HE comes with rich connectivity including HDMI 1.4, Dual-link DVI-D, D-Sub. Users could simultaneously connect VG278HE to Full HD Blu-ray Disc players and myriad HD playback devices like DVD players, audio devices and set-top boxes for limitless entertainment with its built-in stereo speakers
Features:-
- Ultra smooth action with 144Hz rapid refresh rate and 2ms (GTG) tracer-free
- Vivid color performance with Splendid™ Video Intelligence Technology
- A comfortable viewing with ergonomic design for swivel, tilt angle, and height adjustment
- Extensive connectivity with HDMI 1.4, dual-link DVI-D, and D-sub
- VG278HE supports NVIDIA 3D Vision 2 through connection of Dual-link DVI.
- Suggest purchasing the additional NVIDIA 3D Vision 2 Kit for immersive 3D enjoyment, also available from OcUK!
Specification:-
- Panel Size: Wide Screen 27.0"(68.6cm) 16:9
- Pixel Pitch: 0.311mm
- Brightness(Max): 300 cd/?
- ASUS Smart Contrast Ratio (ASCR): 50000000:1
- Response Time: 2ms (Gray to Gray)
- Trace Free Technology
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard Mode/Night View Mode/Game Mode)
- Color Temperature Selection : 4 Modes
- HDCP support
- Stereo Speakers : 3W x 2 Stereo RMS
- Signal Input : HDMI , D-Sub, Dual-link DVI-D (support NVIDIA 3D Vision)
- AV Audio Input : HDMI 1.4
- Audio Output : HDMI 1.4
- Power Consumption(Typical): <65W
- Power Saving Mode: <1W
- Power Off Mode: <1W
- Voltage: 100-240V, 50/60Hz
- Chassis Colors : Black
- Tilt : +15°~-5°
- Swivel : Yes
- Height Adjustment : Yes
- Kensington lock
- Phys.Dimension with Stand(WxHxD):643x437.8x249.7mm
- Phys. Dimension without Stand(WxHxD):643x385.6x59.5mm(For VESA Wall Mount)
- Box Dimension(WxHxD):732x560x176mm
- Net Weight (Esti.): 8kg
- Gross Weight (Esti.): 10kg
- Warranty: 3yr
Was [£399.95] Inc. VAT
Only £359.99 inc VAT.
ORDER NOW
Asus VG278HR 27" TRUE 144Hz 3D Widescreen LED Monitor with NVIDIA 3D Vision 2.0 Glasses - Black @ £455.99 inc VAT
Enter an immersive 3D full HD 1080p world of games and movies with the VG278H. Through the use of the world's first NVIDIA® 3D Vision™ 2 glasses technology, it instantly takes you into another dimension - transforming all your gaming experiences and movies to 3D. With its new technology, it delivers twice sharper 3D images than conventional 3D technology. There are more than five hundreds popular PC game titles* currently compatible with the NVIDIA® 3D Vision™ Kit.
Supported by Trace Free II Technology, the VG278H is able to double the refresh rate to 144 frames per second, which is twice faster than generic LCD monitors, delivering ultra-smooth 3D visuals. Moreover, the response time is now reduced to 2ms to eliminate tracing and ensure crisp and clear video playback.
The VG278H reduces LCD charging time to further prevent mura, ghosting, and bright-line effects, and delivers clear motion scenes during 3D gaming and movie watching. Splendid™ Video Intelligence Technology is built upon a color engine that automatically analyzes and determines the nature of the user’s current task, thereafter adjusting the display’s parameters accordingly to ensure the color accuracy and image fidelity. Six preset video modes (Scenery, Theater, Game, Night View, sRGB, and Standard) can be selected via a hotkey. he VG278H is specially designed with swivel, tilt and height adjustment to suit your preferred viewing angles in 3D gaming and movie watching. The angle-adjustable 3D emitter optimizes 3D for every scenario; simply switch between three IR signal coverage areas via OSD menu and aim the angle-adjustable 3D emitter at shutter glasses for maximum 3D reception. Display stereoscopic 3D via Blu-ray Disc players or game consoles through HDMI 1.4 output. The VG278H offers high compatibility with any media devices with HDMI 1.4, dual-link DVI-D, and D-sub.
Features:-
- Uncompromised 27” 3D immersion with NVIDIA® 3D Vision™ 2 glasses and 3D LightBoost™
- Ultra smooth action with 144Hz refresh rate and 2ms tracer-free
- Ergonomic design for swivel, tilt angle, and height adjustment
- Full HD 1080P : Yes
- Pixel Pitch : 0.311mm
- ASUS Smart Contrast Ratio (ASCR) : 50000000:1
- SPLENDID Video Preset Modes : 6 Modes (sRGB Mode/Scenery Mode/Theater Mode/Standard - Mode/Night View Mode/Game Mode)
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Phys.Dimension(WxHxD): 643x460x220mm
- Net Weight (Esti.): 8 kg
- Dual-link DVI cable
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- Nvidia 3D Vision Kit
- 3yr Warranty
Was [£499.99] Inc. VAT
Only £455.99 inc VAT.
ORDER NOW
DGM IPS-2701WPH 27" LED Widescreen Professional Monitor - Black @ £369.95 inc VAT
The IPS-2701WPH is DGM's new WQHD resolution monitor built around LED backlight LG IPS panels. Featuring a 2560x1440 resolution [WQHD], these monitors are ideal for creative professionals and gamers who demand nothing but the very best. IPS panels are preferred for their superior true color values, the most consistent image and a superior viewing angle as compared to other LCD technologies.
The DGM IPS-2701WPH features the same high resolution LED LG IPS panel found in the Apple Cinema Displays. Video content bypasses scalers making the DGM IPS-2701WPH ideal for gaming and multimedia video production. The superfast 6ms response [grey to grey] minimises streaking and ghosting resulting in visibly less smear and blur around fast moving objects.
Features:-
- Panel Size: 27" Diagonal IPS Panel
- Aspect Ratio: 16:9
- Resolution: 2560 x 1440 (WQHD)
- Pixel Pitch: 0.2331 mm
- Brightness (cd/m2): 350cd/m2
- Contrast Ratio (Typ.): 1000:1
- Dynamic Contrast Ratio (Typ.): 80,000
- Response time (ms): 6ms
- Viewing Angle, H/V: 178 degree(H) / 178 degree(V)
- Input Signal: HDMI (Max resolution on HDMI is 1920x1080), Dual Link DVI-D, DP (Display Port), VGA (D-sub 15pin)
- HDCP Support: YES
- Internal Speaker: Built-in Stereo Speakers
- Wall Mount: VESA 100 x 100 mm
- Net / Gross Weight: 7.6 / 10.3 Kg
- Monitor Dimension (W*H*D mm): 645 × 487 × 172 mm
- Carton Dimension (W*H*D mm): 720 × 510 × 130 mm
- 3yr Warranty return to base with OcUK
Was [£395.99] Inc. VAT
Only £369.95 inc VAT.
ORDER NOW
Some awesome monitor deals for you guys!
- 21.5" (16:9)
- LED Technology
- Wall Mount: No
- 3yr Warranty
ORDER NOW
Features:-
- HDCP support
- Auto. Adjustment
- Volume Adjustment
- Input Selection
- Tilt : +20°~-5°
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
ORDER NOW
Features:-
Specification:-
- VESA: 100x100mm
- Weight: 3.7kg
- Warranty: 3yr
ORDER NOW
Features:-
Specification:-
- VESA: 100x100mm
- Weight: 4.0kg
- Warranty: 3yr
ORDER NOW
Features
- Colors: 16.7 M
ORDER NOW
Features:-
- 5ms Response Time
- Colours: 16.7M
- LED Technology
- 3yr Warranty
ORDER NOW
Features:-
Specification:-
- Colours: 16.7M
- Weight: 5.5kg
- Warranty: 3yr
ORDER NOW
Features:-
- Height Adjustable
- Weight: 8.80kg
ORDER NOW
Features:-
Specification:-
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- Warranty: 3yr
ORDER NOW
Features:-
- HDCP support
- Tilt : +15°~-5°
- Swivel : Yes
- Kensington lock
- VGA cable
- Audio cable
- Power cord
- Quick start guide
- Warranty Card
- 3yr Warranty
ORDER NOW
Features:-
- HDCP Support: YES
ORDER NOW
And the res is way to big for my spec.
