So, in all my years, I have never had a xfire setup. Always opting for cheaper mobos since xfire was plagued with microstutter issues and I would just upgrade my gpu. But not this time! My most recent build has provisions for xfire (GB z77x d3h, corsair TX750 PSU), so I'm considering dropping a second 7950 in.
Here's the part where I get scared!
1) my 3570K is quite heavily overclocked, and adding a second 7950 which I will probably end up overclocking at least a bit (I suspect heat will cause an issue), I now wonder if 750W is enough.
2) I have heard about different brands of card with slightly different pcbs etc not getting on well together in xfire. I have a HIS IceQ 7950, which has a chunky cooler that would fit another of the same in next to it. So I plan on using that as the bottom card (especially since it exhausts heat out the back and should reduce the effect on the top card), and will be picking something else for the top card. So should I be worried about compatibility/synch issues, or can I just plonk and decent card that fits in there?
3) is it worth it?
Thanks in advance for any advice!
3) is it worth it?
