- 2 Dec 2012
- Lincolnshire.
Hello OCUK
Apologies if I have written this thread in the wrong forum, I looked down the list of sub-forums but I couldn't decide which one to categorize this one under so if a Moderator could move it (if it needs moving) I would be very grateful.
So down to my issue:
I've had my computer since around January time and ever since then it's had one persisting problem. TRANSPARENCY. I know this is pretty obscure but hear me out.
So whenever I have Windows Aero enabled my computer lags. Not as in my CPU usage is being guzzled like a cold pint on a hot summers day, but lag as in frame rate sort of speak. Having Aero enabled causes my games to be slower, my mouse (in game or out of game) to be slower in responsiveness, my windows to lag when I move them around my screen (Very very bad lag may I point out), Lag when opening and closing windows (You can really see it), Typing delay lag. The list can go on. I have a program called "Microsoft Fix It" which ASUS recommended me to get and it says:
However, All of this disappears when I go into Windows Basic mode. By now you'd probably think "Why not just stay in Basic mode and shut up then?" Well, Basic mode isn't exactly problem free either. Whenever I move my windows around in basic mode, both of my monitors flash white constantly for the duration of me moving the window until I stop, and when I cross a window to another screen they stay white permanently until I bring that window back to the window it was opened on. (Weird right?)
After speaking with technical support of the distributor they said that I need to try my GPU in a friends PC to see if it's the card, and if the card works fine then it might be the PCI-E controller inside the CPU that isn't working correctly, or the motherboard.
Either way, Can I get some advice from you guys on what this might be or potential fixes?
Thanks in advance for baring with me.
Specs:
CPU: Intel™ Core i5 3570K (Ivybridge) @ 4.6GHz
CPU Cooler: Corsair H80i
Motherboard: ASUS Sabertooth Z77 (LGA1155)
Memory: Corsair Dominator Platinum 16GB (4x4GB) @ 1600Mhz
SSD #1 (Boot Drive): Corsair Force 3 120GB
SSD #2: OCZ Agility 3 60GB
HDD #1: Samsung Spinpoint F3 1TB
HDD #2: Seagate Barracuda 500GB 6GB/s
GPU: MSI GeForce GTX 660 Ti OC 2GB
PSU: Corsair HX850W Modular 80+ PLUS Silver Certified
Optical Drive: LG 22x DVD/RW
Sound: ASUS Xonar Essence STX
Case: Corsair Carbide 500R
Running dual 24" monitors at 1920 x 1080.
Your video card does not support Windows Aero. Install a video card that supports this feature. Your video card does not support DirectX 9.0 or OpenGL 2.0.
Specs:
