***The Vapers Lounge***
Status
Not open for further replies.
Well you live and learn. Always have backups. To be fair I broke a protank (was the backup) on holiday and forgot my wire for my aga T2. Was on fags again for 1/2 a morning until I got a mini nova and a iclear 30. Had to pay almost double what they cost in the UK (let alone fasttech)
I know this is kind of a one off but you might look into a small fuse for your mod. Something like the 2 cent or bug. I guess your mod likely has a hot spring but that only works to brake the current after the battery is pretty far gone.
The problem is the 510 connector on the dingo got stuck to the t2 so i had to order a new RBA so ive ordered a DID.
All my cartos are ****** so I decided to ghetto rig my dingo till the DID comes which is working atm but your right about maybe getting a bug for my dingo.
Thank god im proficient in coiling now so I can vape this even though im using the stuck 510 connector on the T2 :P
Oh I know I've read all your posts. The advice still stands.
Trying a prototype from Simon - think it's going back in the dark for a few days... All I'm getting is the taste of 3 week old Shisha water, that you accidentally suck up the tube... Bleurgh!
Smells nice though...
What flavour is it? I emailed him asking/begging him to try and make a Starbuzz Blue Mist clone :D
I'm afraid that's classified :D
Ever since the Bananana was prematurely released, Simon's being very careful not to mention a flavour he's testing out.
Redmogg, which one is is it, give me a character from the beggining or the sixth character is an a for example. That way I know which one you're talking about xD
EDIT: never mind I know which one it is now Si said!
I didn't get on with that one personally, I've left it sitting for a few days/a week to try it again though.
I bought a EGO 5+ wickless ecig with some Diamond Mist L&B liquid the other day. There was a problem with the kit as it only worked sporadicaly and it leaked. When it did work, I did not like the taste. I took it back to the shop and was given a refund,
I tried some cherry flavoured liquid and it was much better than the Lambert and Butler liquid, so I'm wondering if I shoud try again.
What are your thoughts about wickless, as opposed to wick kit and have been really unlucky with the leaking problem.
I have already tried the catridge type which looks like a cigarette but I did not like it as I had to really drag on it to get anything.
My eventual aim is to stop smoking and I do not want to invest in expensive kit so could somebody give me a list of recommended kit for £20 and under which I can buy from the local shop. I tried to look in this thread but it is so detailed that I am lost.
Thanks
Home Bargains have just started selling Cloud 9 stuff, they have a single eGo battery/charger/clearo for £7.99 and then 3 lots of 18mg 10ml juice (Tobacco/Menthol/Blueberry) at £1.99 each...
Nevered used a CE5+, I presume that is the one you're referring to. I don't think they are totally wickless, as there must be some kind of wicking material inside the center post.
I have both the CE4 and CE5, the CE5 is rubbish. It never leaked but gave me loads of dry hits and burning favour. The CE4 was much better but they last about 2 weeks before they need replacing.
I would recommend something like the EVOD which is basically a mini ProTank, it has the same setup. CE clearomisers gives better favour when they work because the coil sits so high up. The EVOD is bottom coiled, so less chance of dry hits and fits on any eGo type battery.
I think it must be the CE that has a SS mesh wick in the inside. Most reviews aren't great for it. I'd go with an ego and a Evod. I don't know what you might be able to buy local. I buy all my stuff online.
Well,
I've quickly learnt not to take one of your new e-cigs on a night out, have lost one and no idea where it went!
Thank god it came with two!
Disposable e-cigs for nights out moving forward!
+1 for the Ego & Evods. There's a starter kit by Vision on www.vapeland.co.uk, a little more than £25.
Buy your liquid from www.joosejuice.co.uk, as their 10ml samplers are only £1.49 (90p p&p) - when you find a flavour you like, they do BOGOF on the 30ml bottles = £7.25 for 60ml!
Unless you're paying through the nose for the el torro cigarillos range, avoid cigarette brand named flavours as they won't taste anything like a stinky. RY4 being the exception to this, it's more a case, caramel, nutty flavour, depending on where you buy it.
Was smokedog that made the suggestion and I just agreed. So +2 really. Just to be clear RY4 doesn't taste like a fag either it just happens to sometimes be nice. Thing with RY4 is bar maybe being a bit caramel like they all taste different.
What kind of mix is typical, a 50/50?
Their website makes my eyes sore, the user journey is terrible :p
its the ratio of the liquids used to make the juice
Usually PG will give you more throat hit and Flavour.
VG will give you more Vaper, but does not carry flavourings so well and is usually thicker
I started off on 70/30, (pg/vg) but recently i seem to prefer 50/50
Hey is this a good starter kit
http://www.thealchemistscupboard.co.uk/product/gold%20diy%20mixing%20kit
I hear the place is good to deal with. Also I'm trying to work out how much 18mg that lot would make?
My maths might be bad but I think 400mls? You'd run out of flavouring well before that and would be short on PG / VG maybe depending how you mixed it. I think there is enough flavouring included to make around 100mls since most of the included flavours need around 20%
Status
