COMPETITION: £2000 BUILD OFF, SPEC ME SOME NERD PORN
hows this??? ;)
you get a tube of gelid extreme with the ek waterblock
YOUR BASKET
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - Retail £197.99
1 x Corsair AX760i Digital ATX '80 Plus Platinum' Modular Power Supply (CP-9020036-UK) £179.99
2 x HIS HD 7950 3072MB GDDR5 PCI-Express Graphics Card (H795F3G2M) £175.99 (£351.98)
1 x Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard £169.99
1 x Asus VN248H 24"Widescreen Super Narrow Bezel LED Monitor - Black £169.99
1 x Corsair Carbide 540 High Airflow ATX Cube Case - Black £113.99
1 x OcUK Tech Lab - 18w DDC Pump & EK-DDC X-RES 140 CSQ Value Combo £105.98
1 x Corsair Force GS 128GB 2.5" SATA 6Gb/s Solid State Hard Drive (CSSD-F128GBGS-BK) £99.98
1 x Microsoft Windows 8 64-Bit DVD - OEM (WN7-00403) £79.99
1 x TeamGroup Xtreem LV 8GB (2x4GB) DDR3 PC3-19200C10 2400MHz Dual Channel Memory Kit (TXD38G2400HC10QDC01) £79.99
1 x EK Water Blocks EK-Supremacy Clean CSQ - Nickel £56.99
1 x TT eSports Challenger Pro Gaming Keyboard £47.99
1 x XSPC RS240 120mm Radiator - Black £39.95
1 x Seagate Barracuda 7200.12 500GB SATA 6Gb/s 16MB Cache - OEM (ST500DM002) HDD £39.95
1 x Mad Catz Cyborg R.A.T.3 3500 DPI Gaming Mouse - Red £39.95
1 x BitFenix Hydra Fan/LED Controller £24.98
1 x Mayhems Pastel - Ice White Coolant 1L £14.99
6 x Enermax Magma UCMA12 120mm Fan £9.98 (£59.88)
2 x BitFenix Alchemy Premium Modding LED Strip - Connect White 12cm £9.29 (£18.58)
6 x Bitspower Connection 1/4 inch to 16/11mm - blood red £8.99 (£53.94)
1 x BitFenix Alchemy 24pin ATX extension 30cm - Red £8.99
4 x BitFenix Alchemy 6pin PCI-E extension 45cm - Red £6.49 (£25.96)
1 x Primochill Primoflex Advanced Tubing 16/10 - Clear £5.99
1 x BitFenix Alchemy 8pin EPS extension 45cm - Red £5.99
1 x EpicGear Hybrid Gaming Surface - Small £5.99
Total : £2,000.00 (includes shipping : FREE).
I think i did it.
A red/white and Black 2011 mATX build. :D
YOUR BASKET
1 x MSI HD 7970 GHz Twin FrozR OC BE 3072MB GDDR5 PCI-Express Graphics Card with FREE GAMES £269.99
1 x Intel Core i7-3820 3.60GHz (Sandybridge-E) Socket LGA2011 Processor - Retail £259.99
1 x Asus Rampage IV GENE Intel X79 (Socket 2011) DDR3 MicroATX Motherboard £239.99
1 x Parvum Systems S1.0 MicroATX Case - White with Red £139.99
1 x GeIL EVO Veloce Hot-Rod Red 16GB (4x4GB) DDR3 PC3-14900C10 1866MHz Quad Channel Kit (GEV316GB1866C10QC) £119.99
1 x Zowie Celeritas White Limited Edition Mechanical Keyboard - Red Switch £112.99
1 x OcUK Tech Lab - 10w DDC Pump & EK-DDC X-RES 100 CSQ Value Combo £89.99
1 x XSPC Razor 7970 VGA Waterblock £84.98
1 x Antec High Current Gamer 620W '80 Plus Bronze' Power Supply £69.95
1 x EK-Supreme LTX - Acetal CSQ Intel CPU Waterblock £39.98
1 x SteelSeries Kinzu V2 Pro Edition 3200 DPI Gaming Mouse - Red (62025) £39.95
2 x Hardware Labs Black ICE Radiator GT Stealth 240 £35.99 (£71.98)
1 x Mayhems X1 UV Red Premixed Watercooling Fluid 1L £7.99
1 x BitFenix Alchemy 24-Pin ATX Extension 30cm - sleeved black/red/black £7.49
1 x Arctic Cooling MX-2 Thermal Compound (4g) £6.98
1 x BitFenix 6-Pin PCIe Extension 45cm - sleeved black/red/black £5.99
4 x BitFenix Spectre 120mm Fan - White £5.99 (£23.96)
1 x BitFenix 8-Pin PCIe Extension 45cm - sleeved black/red/black £5.95
8 x Bitspower 1/4" Thread Stubby Barb Fitting for 7/16" ID (11mm) Tubing Deluxe White £4.99 (£39.92)
1 x BitFenix Alchemy 8-Pin EPS12V Extension 45cm - sleeved black/red/black £4.99
2 x XSPC 7/16" ID [16/11mm] High Flex Hose - Clear [1m Length] £2.99 (£5.98)
Total : £1,999.00 (includes shipping : FREE).
Mine too! ... not that my spec would have been in any way decent anyway :p
Edit: So I'll edit my entry into this post when I've done it... oops, forgot about that 1st post rule when I wrote this!
its OK Dave as long as you don't post a spec then create another post with a edited spec mate.
EDIT: Doomedspeed I have just trusted you my Skype details, if you need work on a database I'm ya man.
My priorities are fine, I honestly have no idea what you mean... :D
YOUR BASKET
1 x Asus Z87 SABERTOOTH Intel Z87 (Socket 1150) DDR3 ATX Motherboard £199.99
1 x Intel Core i5-4670K 3.40GHz (Haswell) Socket LGA1150 Processor - OEM £191.99
1 x Watercool Heatkiller GPU-X³ 79X0 Ni-Bl £89.99
1 x XSPC AX360 Triple Fan Radiator - White £89.99
1 x Samsung 120GB SSD 840 EVO SATA 6Gb/s Basic - (MZ-7TE120BW) £84.95
1 x OcUK Tech Lab - XSPC D5 Vario Pump & EK-D5 X-TOP White Acetal Value Combo £81.98
1 x XFX Pro 750W Core Edition '80 Plus Bronze' Power Supply £79.99
1 x Asus VW199DR 19" LED Widescreen Monitor - Black £79.99
1 x XSPC AX240 Dual Fan Radiator - White £74.95
1 x Corsair Vengeance Low Profile 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9) £71.99
1 x Corsair Vengeance Arctic White 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Kit (CML8GX3M2A1600C9W) £65.99
1 x Koolance CPU-380I Water Block (Intel Processor) £63.95
1 x XSPC Photon 170 Tube Reservoir £37.99
2 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - White £29.99 (£59.98)
1 x BitFenix Alchemy Cable Bundle - White £28.45
5 x Corsair SP120 Performance Series High Pressure - Dual Pack (CO-9050008-WW) £25.99 (£129.95)
2 x Mayhems Pastel - Ice White Coolant 1L £14.99 (£29.98)
1 x NZXT CB-LED20-WT 24x White LED Sleeve - 2m £13.99
1 x Gigabyte KM6150 Keyboard and Mouse Set £9.98
1 x NZXT Front Panel connections cable set 30cm sleeved - Black £5.99
2 x Primochill Primoflex Advanced Tubing 19/13 - Clear £5.99 (£11.98)
1 x BitFenix Alchemy Internal USB Extension 30cm - sleeved black/black £4.98
1 x BitFenix Alchemy Internal Audio Extension Adaptor 30cm - Black £4.49
2 x Akasa AK-CB002 PWM Fan Splitter Cable £3.59 (£7.18)
4 x XSPC G1/4" 45° Rotary Fitting (Chrome) £3.49 (£13.96)
Total : £1,998.62 (includes shipping : FREE).
True porn :D
Sabretooth, white and black RAM, white sided rads, SP120's with white rings, nickel blocks, white lighting, white braided cables, white fittings, tube res with white glow, clear tubing with white coolant :D
Simple in many ways, yet elegant. The black of the RAM and the center of the CPU block, along with the deep grey of the motherboard, the dark PCB on the GPU and the inside of the case will create a nice contrast with the white when the light hits it. Front panel cables with black braid so that they don't stand out at all etc. :)
Pump can go on the un-seen side, as of course will the SSD and the PSU with all of its un-needed cables. :)
Like you're going to be looking at the peripherals anyway... :rolleyes:
Revised previous post, removed 2x un-needed fittings, added white lighting. :)
*edit* or not... Hang on :p
Revised first post again, added 2x fittings that I forgot (i cant count) and removed 2x angled fittings. :)
YOUR BASKET
1 x XSPC D5 Dual Bay Reservoir/Pump Combo V2 £122.99
1 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting Six Pack - White £29.99
4 x Monsoon 19/13mm (ID 1/2 OD 3/4) Free Center Compression Fitting - White £6.49 (£25.96)
Total : £1,997.62 (includes shipping : FREE).
Bay res won't work in that case :D
Your basket
Product Name Qty Price Line Total
MSI HD 7990 6144MB GDDR5 PCI-Express Graphics Card with FREE GAMES MSI HD 7990 6144MB GDDR5 PCI-Express Graphics Card with FREE GAMES £529.99
(£441.66) £529.99
(£441.66)
Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail Intel Core i7-4770K 3.50GHz (Haswell) Socket LGA1150 Processor - Retail £275.99
(£229.99) £275.99
(£229.99)
Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard Asus Z87 MAXIMUS VI HERO Intel Z87 (Socket 1150) DDR3 ATX Motherboard £169.99
(£141.66) £169.99
(£141.66)
Cooler Master Silent Pro Modular 2 850w '80 Plus Silver' Modular Power Supply Cooler Master Silent Pro Modular 2 850w '80 Plus Silver' Modular Power Supply £119.99
(£99.99) £119.99
(£99.99)
Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) HDD Western Digital Caviar Black 2TB SATA 6Gb/s 64MB Cache - OEM (WD2002FAEX) HDD £117.00
(£97.50) £117.00
(£97.50)
Corsair Carbide 540 High Airflow ATX Cube Case - Black Corsair Carbide 540 High Airflow ATX Cube Case - Black £113.99
(£94.99) £113.99
(£94.99)
Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) Corsair Hydro H110 280mm High Performance Liquid CPU Cooler (CW-9060014-WW) £94.99
(£79.16) £94.99
(£79.16)
Patriot Venom Red 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (PV38G160C9KRD) Patriot Venom Red 8GB (2x4GB) DDR3 PC3-12800C9 1600MHz Dual Channel Memory Kit (PV38G160C9KRD) £59.99
(£49.99) £59.99
(£49.99)
Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) Cooler Master 12cm Sickleflow Red LED System Case Fan - (CM-R4-L2R-20AR-R1) £6.98
(£5.82) £34.90
(£29.10)
BitFenix 6+2-Pin PCIe Extension 45cm - sleeved red/black BitFenix 6+2-Pin PCIe Extension 45cm - sleeved red/black £5.99
(£4.99) £11.98
(£9.98)
total:£1543
Lol, don't even need £2000, best i can come up with
edit: i'd best add some peripherals:
Asus VG248QE 24" Widescreen 144Hz 1ms Gaming LED Monitor - Black Asus VG248QE 24" Widescreen 144Hz 1ms Gaming LED Monitor - Black £289.99
(£241.66) £289.99
(£241.66)
TT eSports Challenger Pro Gaming Keyboard TT eSports Challenger Pro Gaming Keyboard £47.99
(£39.99) £47.99
(£39.99)
Corsair Raptor M40 Gaming Mouse (CH-9000041-EU) Corsair Raptor M40 Gaming Mouse (CH-9000041-EU) £44.99
(£37.49) £44.99
(£37.49)
new total: £1939.47
Can I use free linux as an OS? :D
Spec's must include everything from the following:
TOWER
MONITOR
MOUSE
KEYBOARD
OPERATING SYSTEM
All entries must use the **Multi-Browser OcUK Shopping Cart Bookmarklet** as created by Pho (found here http://forums.overclockers.co.uk/showthread.php?t=18371076). Entires that don't use this will be void.
Good try but nope :p read Rule 7)
RULES:
1) All entires will be judged by ETHERMASTER & STULID, our decision is final.
2) Judges are not allows to enter.
3) Your first post will count as your entry, if you wish to amend your entry please edit your first post (multipliable entries will be void).
4) Closing date for entries is Friday 6th September 2013 @ 12:00 GMT, entires made after this are are not valid.
5) Entrants must have a STEAM account.
6) The shipping cost is not including on all entries, just the value of the parts.
7) All parts used must be available from OcUK.
