Hi,
After taking my MK2 Focus to the garage this morning to sort out a steering wheel wobble that I've had for a while, I was told that the front left alloy had a flat spot and needed replacing. The other 3 alloys are also in bad condition and definitely could do with a refurb. These are the wheels that came with the car http://www.fordpartsuk.com/shop/ford_focus_mk2_65_x_17_alloy_wheel_f_1384604_c_259.htm. Therefore, my question to you is what it the best course of action, or more like, what would you do in my situation?
The way I see it these are my options:
1) Get all 4 wheels repaired/refurbed. I've rang a local company to be told that, including the straightening of the flat wheel, it's £384 for all 4. They can't book me in until 1st of November though. Also, if they can't repair the damaged wheel, I've wasted 2 months of waiting.
2) Try and find some 2nd hand original focus wheels. I'v had a scour around and couldn't really find much and there is the potential that they'll need a refurb as well.
3) Buy some aftermarket alloys. I've found some half decent looking ones for the £330 mark. This option has the benefit that I'll be confident of the condition of the wheels.
4) Buy 4 brand new Ford Wheels. This comes to £700 plus delivery and probably not worth it considering the value of the car.
I'm leaning towards number 3 as it's probably the cheapest option and the condition of the wheels will be good. But which wheels and where from? Any advice?
Cheers
Cheers
